Vacuum Reservoir - JeepForum.com
post #1 of 22 Old 10-16-2013, 02:47 AM Thread Starter
chuck172
Vacuum Reservoir
Did all YJ's come with the Vacuum Reservoir under the battery?
I don't believe I have one.
chuck172 is offline
post #2 of 22 Old 10-16-2013, 04:41 AM
superj
yes. mine is not hooked up anymore though
I don't feel like working on anything at this time so i sold my yj.
superj is offline
post #3 of 22 Old 10-16-2013, 06:46 AM
SeanB95YJ
are you confusing a vacuum reservoir with the charcoal (evap) canister maybe?
look on your firewall on the driver side way under the brake booster... that's where my charcoal can is (95)
Sean B. - Schenectady, NY - 95 YJ, 350/700r4/NP241, JB Shorty SYE, 8.8 rear, 2" BDS, 1" homebrew shackles, Daystar 1" BL, TJ flares, 35x12.50 General Grabber AT2 on 15x10 Bart D-Truckers, Polyshield polycarbonate windshield, HD over/under crossover steering
swap/build thread:
SeanB95YJ is offline
post #4 of 22 Old 10-16-2013, 07:05 AM
superj
no, there is one for the 4x4 system under hte battery
superj is offline
post #5 of 22 Old 10-16-2013, 07:08 AM
vadslram
Mine looks like a black softball with a vacum hose going to it. Next to the charcoal canister.
vadslram is offline
post #6 of 22 Old 10-16-2013, 07:10 AM
superj
hmm, maybe since ya'lls are newer they are on the driver's side. mine is the softball looking one also but on the other side of the bay
superj is offline
post #7 of 22 Old 10-16-2013, 09:10 AM Thread Starter
chuck172
I'm not talking about the charcoal canister, the vaccum reservoir. I understand it's located right below the battery. I don't think I have one.
chuck172 is offline
post #8 of 22 Old 10-16-2013, 09:19 AM
tom_sprecher
Judging by the profiles, maybe the newer models (91 and up) do not have vacuum reservoirs. Mine does not.
Tom
tom_sprecher is offline
post #9 of 22 Old 10-16-2013, 10:09 AM
superj
you know what, thinking back to my wife's 93 yj, hers didn't have one under the battery tray. i had to rerun all her 4x4 vacuum lines and they went straight from the t-case switch to the front axle, not to a reservoir like my 87 has
superj is offline
post #10 of 22 Old 10-16-2013, 11:10 AM
vadslram
Although the reservior isn't essential for it to run it does make things like the heat and 4wd work with less glitches.
If you already did a manual disco and don't mind if the heat shifts around at WOT then by all means get rid of it.
But they weigh like a pound, have no moving parts and you can use ANY vehicle make and model in the jeep. It's just a big airtight empty. TJs and ZJs have a flat one you can get at Morris's for less than $30 brand new.
vadslram is offline
post #11 of 22 Old 10-20-2013, 06:22 AM Thread Starter
chuck172
How bout this, does anyone with a newer yj (92-95) have a Vacuum Reservoir?
chuck172 is offline
post #12 of 22 Old 10-20-2013, 12:14 PM
djfred
I have a 92 and mines empty under the battery.
--Now--
White 92 YJ -- RE 1.5" SOA -- BFG KM2 35x12.50x15 -- D30 (4.88 w/ ARB) -- Ford 8.8 (4.88 w/ ARB)
Sanden OBA
--Future Mod--
Flat Fenders
djfred is offline
post #13 of 22 Old 10-20-2013, 04:37 PM
bpounds
bpounds's Avatar
Most vehicles will have a vacuum resevoir. Even diesels that have an electric motor to create vacuum will have one.
As mentioned, the resevoir makes all the vacuum operated devices work more efficiently. It also prevents a massive loss of vacuum in the motor when you turn something on that uses vacuum. Without the resevoir, your engine would run rich for a moment, essentially the equivalent of a vacuum leak. Think of your brake booster for example, which uses a lot of vacuum when you press the service brake.
Bill
Dodge did not build my Jeep.
1988 Wrangler,4.2L I-6, Howell EFI JP-1,CRT HEI Ign,AX15 ext slave conversion, Zone 2.5" lift + 1/2" booms, BFG 31 x 10.5, Bestop.
bpounds is offline
post #14 of 22 Old 10-20-2013, 06:08 PM
fishadventure
I thought that only one fresh air heater 'door' was vac operated; the rest are cable run. I was not planning on using any vac lines on my '91 as the front axle is going to be a cable posi-lock. Please tell me more...
fishadventure is offline
post #15 of 22 Old 10-20-2013, 07:39 PM
jay-h
You can get general purpose ones, you don't have to find the original.
http://www.summitracing.com/search/p...uum-reservoirs
My toys
'89 Wrangler YJ
'47 CJ2-A
wife's toys
97 Grand Cherokee (ZJ)
87 MB 560SL roadster
jay-h is offline
