vacuum readings question - Page 2 - JeepForum.com
post #16 of 21 Old 09-27-2013, 09:00 PM
Old4X
1990 CJ7
Don't have an Offy, but With either an extension, or an extension and a squiggly joint, I had no problems doing mine.
I got a Holley refurb once and it looked brand new. It did have a problem, though. One linkage part was bent and caused the throttle to stick. Took a while to figure out what was going on, and was likely the reason it was returned. A little Kentucky windage applied to said linkage and it is as slick as an eel in a barrel of snot.
Look yours over well, if anything is wrong, it is probably minor.
418 miles on 19 gallons of gas. Can't beat the BBD !
Old4X is offline
post #17 of 21 Old 09-27-2013, 09:41 PM Thread Starter
ForestJeep89
Haha that's great. Ill look er over real nice.
Yeah I think it is the water jacket underneath that wont let me go straight on and so far I cant find an angle with the squiggly do-hicky,real tight in there.anyhoo I keep at it.
ForestJeep89 is offline
post #18 of 21 Old 10-14-2013, 11:54 AM Thread Starter
ForestJeep89
Well anyways...instead of letting this thread trail off I'll update it now for future searches.
Got my Holley in the mail as well as spacers and other gear, ordered quick change kit for secondary tune and I am absolutely thrilled with the new carb which was flawless other than needing cam position, pump arm, throttle blade, and choke adjustments! After much tightening and making sure of proper intake manifold, vacuum tubing and carb installation, I fired it up and she runs great!
Only problem was my gauge was still showing that intermittent drop off of vacuum pressure...Aargh!
as you can imagine I was very freaked out to see the gauge doing that still so I grabbed the gauge to bring it closer to my face and the pressure went up.......so I put the gauge back where it was and the pressure dropped.......and again I did this a couple more times to verify that all along my problem was a failing mityvac handpump vacuum gauge that doesn't like being held in a certain position due to the needle valve under the trigger release.
So...in conclusion, I would say if you're going to start getting into mechanics (which I recently did), always always always give attention to the most simplest things first first first. probably starting by making sure you are dressed before you leave the house.
Post Script: Ya'll would have loved to have been there when I had to give my wife the update ya'll just got. (She was amazingly understanding, but boy did I feel dumb.)
Here's some pics of the outcome. (Sound of one person clapping slowly).
post #19 of 21 Old 10-14-2013, 02:19 PM
roadyrob
1987 YJ Wrangler
I'm sure most here have had those oh **** moments, sometimes its the simple things that get ya, glad you figured it out. enjoy your holley, its the perfect carb for the 4.2.
Do everything with a positive attitude, it won't always work but you'll piss enough people off to make it worthwhile.
the voices aren't real but they sure have good ideas.
roadyrob is offline
post #20 of 21 Old 10-15-2013, 08:26 PM Thread Starter
ForestJeep89
tx ,will do
post #21 of 21 Old 10-16-2013, 04:50 AM
superj
it looks great, thats for sure
I don't feel like working on anything at this time so i sold my yj.
superj is offline
