vacuum problems - JeepForum.com
post #1 of 6 Old 04-17-2005, 06:54 AM Thread Starter
wdc
vacuum problems
I have a jeep wrangler 1990 inline 6. I have lost vacuum pressure to almost everyting. Four wheel will not engage. Engine dies at a stop when engaging the clutch. When at idle after warm up rpm's go up and down. Will not idle smoothe unless I throttle slightly. I do have vacuum on vacuum fitting. I have also noticed a slight back pressure sound in exhaust when going down hill. I have checked all the hoses (very many of them) and can't find any leaking. If anyone has any suggestions or solutions to this you help is greatly appreciated. Thank you!!!!!!!
wdc is offline
post #2 of 6 Old 04-17-2005, 07:10 AM
drew2000
drew2000's Avatar
wdc,
Hook up a vacuum gauge to a hose coming from the manifold and get a reading at idle. The two most important things are what the reading is, and how the needle fluctuates. A perfect reading is 18-20 with the needle perfectly still.
If your engine has no vacuum at all, that is a sign of a major problem.
If it fluctuates it can be an indicator of various types of engine problems.
Drew
1994 YJ - 2.5L, 2" BDS w/1" Shackles
2006 Dodge Charger R/T (5.7L Hemi)
drew2000 is offline
post #3 of 6 Old 04-17-2005, 08:59 PM Thread Starter
wdc
Originally Posted by drew2000
wdc,
Drew
Thanks for the info. I checked the vacuum and it is holding steady at about 20. Never had this sort of problem before and it is frustrating me seriously.
wdc is offline
post #4 of 6 Old 04-18-2005, 09:00 AM
Wif
Wif's Avatar
If you have vacuum at the manifold then you must have a leak on one of the lines .. check for cracked and broken vac lines .. these do get brittle.
Formally 88Jeepster
Who's in front ?
Ridin' topless again .. sweet !!
Wif is offline
post #5 of 6 Old 04-18-2005, 09:10 AM
YJBlues
YJBlues's Avatar
I've found that a cheap can of starter fluid is your best friend when trying to track down a vacuum leak. Spray short bursts at the hoses in different locations, when you hear the engine rev when you spray, you've found the general area of the leak.
YJBlues is offline
post #6 of 6 Old 04-18-2005, 10:00 AM
amg61
amg61's Avatar
it's possible you have two unrelated problems. the fact that your 4-wheel drive will not engage is not that uncommon in these jeeps. search the forum for posi-lok solutions and that might help.
as for your idling issues, yes it may very well be a vacuum leak, but assuming you have that old carter carb, you may just have clogged idle tubes. there are a number of threads on this issue, but if you want to tackle your carb, without tossing it and swapping in a weber or mc2100, then try these fixes.
consider this carb fix:
http://www.jeeptech.com/engine/carter.html
with these pictures:
http://www.yellowjeep.org/Carb.html
and consider drilling out the venturi idle tubes to 0.040" with a #60 drill bit (by hand).
Also, a TFI ignition upgrade is great for that engine. search the forum for TFI upgrade info, or got to this site:
http://www.driveajeep.com/html/the__juicebox_.html
also, this site is awesome. http://home.sprynet.com/~dale02/list.htm
TFI/GM HEI Hybrid, MC2100, M.O.R.E. greasable shackles, TJ flares, AtoZ Fab Rocker panel, 31" BFG AT; Getting there.....
amg61 is offline
Vacuum Disconnect Problems Alabamaranger YJ Wrangler Technical Forum 7 02-04-2010 02:25 PM
vacuum problems Bryan01702 YJ Wrangler Technical Forum 2 01-26-2010 06:56 PM
Vacuum line problems. Still no air. TheMightyGoat TJ Wrangler Technical Forum 5 08-31-2007 05:55 PM
vacuum line problems tonyk YJ Wrangler Technical Forum 6 07-31-2005 01:00 PM
4wd problems with vacuum system jeep75 YJ Wrangler Technical Forum 2 09-19-2004 07:43 AM
