Vacuum Line Madness - JeepForum.com
post #1 of 9 Old 09-30-2008, 03:24 AM Thread Starter
DThomas
1987 YJ Wrangler
Vacuum Line Madness
What is the best way to just get rid of all those pesky vacuum lines on my stock 87 YJ and still have an engine that runs?!?
DThomas is offline
post #2 of 9 Old 09-30-2008, 06:09 AM
JeeperDon
Think Outside the Catalog
JeeperDon's Avatar
They are only 'pesky' because you don't know how they work. Get a service manual (aftermarket or OEM), understand what the systems do, and fix any that are problematic.
'93 YJ, '02 GM 4.3V6, SOA, dual ARB's, 8.8+D30(WarnHubs), 4.88s, 35" BFG KM2s, AX15, NP231+4:1+SYE+2LO, York OBA, Warn M8000.
Web Admin for
JeeperDon is offline
post #3 of 9 Old 09-30-2008, 07:31 AM
Gunbunny
1. Carb change (MC2100, Weber, Holley, etc)
2. HEI
Gunbunny is offline
post #4 of 9 Old 09-30-2008, 09:07 AM
brianOU
MPI... i just ripped mine out last week, it was great.... spend 1.5 hr in a junkyard here, and so far i am up tp 300 dollars, and i have nearly everything i need. just have to get my wiring harness on.
brianOU is offline
post #5 of 9 Old 09-30-2008, 11:22 AM
Jim93YJ
Jim93YJ's Avatar
^^^X2 Spend a little time researching all the lines and before you know it, it will all make sense like in the matrix when the vertically scrolling alpha-numeric characters turn into pictures for people who can interpret the code.
OR... there is also tons of info on getting rid alot of the emissions stuff:
http://www.jeepforum.com/forum/f12/ecm-removal-569016/
93YJ 4.8L Vortec,AX15,Atlas 4.3:1, 4.56 Gears, Dana 30 w/ Posi-lok,Dana 44 Rear w/ Ox Locker + 99 Explorer Disk Brakes,Tom Woods D. Shafts,1" Body, 2.5" ED RE Lift, 33" BFG KM2 T/A's with MT Classic II Wheels, Herculined Inside, Electric Fan, 20 Gal Tank Conversion,Tuffy Center Console,Warn Front Bumper, Rockhard 4X4 Rear Bumper w/ Tire Carrier,Bushwacker Extended Flat Fender Flares,AMSoil/Redline In Everything and the List Goes On....
AND...
88YJ 4.2L: Interior and mechanical overhaul including engine replacement, nutter bypass, Weber 34 Carb, and work on a whole bunch of other things to get it back to fine running condition without the emissions control...evap cannister kept functional as well as PCV system, and manifold heater.
Jim93YJ is offline
post #6 of 9 Old 09-30-2008, 11:23 AM
Jim93YJ
Jim93YJ's Avatar
And for the 4wd System.....
AND...
Jim93YJ is offline
post #7 of 9 Old 09-30-2008, 11:54 AM
kloppk
And anutha one...
kloppk is offline
post #8 of 9 Old 09-30-2008, 12:00 PM
northjeep
Jeep parking ONLY
northjeep's Avatar
my vote is for the MPI.
-NorthJeep - >> Just Enough Essential Parts
northjeep is offline
post #9 of 9 Old 10-04-2008, 06:51 AM
Cannon
Cannon's Avatar
Readers digest version.
-Pull and cap it if it's related to emissions. It shouldn't apply anymore for your jeeps' age.
-Inspect & repair if its related to 4wd.
'90YJ Hard & Soft w/Full Drs; 4.2 Rebuild w/ Webber, 30x10.5; Interstate MegatronII D34; Mods: Rock Guards; Hi Lift Inst; Herc'd Tub, Front & Under; Elev Rear Seat; Scty CntrConsole/ Overhead&Rear Boxes; KC Lights-Fr & Rear; PA Sys; Gauges; Int Lts; Batt/Alt Cable; Heater Mods; 8K Winch, KargoMaster Rack w/Yak Megawarrior Basket; Ground Lights (4);Dumped - Optima Yellow after only 4yrs
Cannon is offline
Vacuum line ID?? Line dragging on the ground.. Gunmetal YJ Wrangler Technical Forum 4 01-21-2010 05:07 PM
what is this vacuum line for? jr1966 TJ Wrangler Technical Forum 5 07-04-2009 08:09 AM
90 YJ Vacuum Line dreski1 YJ Wrangler Technical Forum 3 06-18-2009 03:53 PM
Front axle vacuum line help (vacuum help part 2) mrmustang YJ Wrangler Technical Forum 13 02-13-2007 07:26 PM
Vacuum line to 4wd turfman* YJ Wrangler Technical Forum 1 09-14-2002 02:55 PM
