vacuum line boots - JeepForum.com
post #1 of 2 Old 08-27-2007, 07:14 AM Thread Starter
richmond1273
vacuum line boots
while looking through the engine bay looking for another problem i started to notice that most of my vacuum line boots are a little dry rotted. they are hard lines with rubber boots on the ends and i was wondering if anyone had found a place to order them from. i would rather not have to replace all the hardlines with flexible lines if i don't have to. a quick search on yahoo didn't turn much up and i couldn't find anything at the Zone. thanks.
1995 Wrangler 4.0 AX15 NP231 D30 & 35 4.10 gears
3" Rough Country suspension 33x12.50 Mastercraft MT
2007 JK 3.8 42RLE Auto NV241 D30 & D44 4.10 gears
richmond1273 is offline
post #2 of 2 Old 08-27-2007, 11:02 AM
crosschecker
1995 XJ Cherokee
I ended up going through the dealer for the couple I replaced on mine. They weren't even ridiculous in price, give them a try.
'95 XJ 4.0, 2wd converted to 4wd, manual and stock
'96 XJ 4.0 Country, Auto (The new kid)(now in need of an engine)
'99 WJ 4.0, stock
'96 ZJ 5.2 Limited
crosschecker is offline
vacuum line came off...where does it go? Rowingfish87 TJ Wrangler Technical Forum 10 11-17-2011 11:35 AM
Vacuum line ID?? Line dragging on the ground.. Gunmetal YJ Wrangler Technical Forum 4 01-21-2010 05:07 PM
Front axle vacuum line help (vacuum help part 2) mrmustang YJ Wrangler Technical Forum 13 02-13-2007 07:26 PM
4wd vacuum line.HELP!! nightstalker5.0 YJ Wrangler Technical Forum 1 01-16-2005 04:43 PM
one little vacuum line 88heepmangler YJ Wrangler Technical Forum 5 08-17-2004 10:52 PM
