vacuum to engage 4 wheel drive - JeepForum.com
post #1 of 10 Old 05-29-2012, 08:37 PM Thread Starter
01roadking
I am sure you have been asked this many times, but is there a easy way to see if the vacume shifter on a 92 wrangler is working. Is there a schematic that shows how the electric and vacume are to be connected and how they make the connection when the transfer case is shifted into 4 wheel.
Thanks
01roadking is offline
post #2 of 10 Old 05-29-2012, 08:47 PM
Old4X
1990 CJ7
Put it on jack stands and test it out. You will know real quick if the front is locking or not.
418 miles on 19 gallons of gas. Can't beat the BBD !
Old4X is offline
post #3 of 10 Old 05-29-2012, 08:51 PM
4x4JB
I'm pretty sure I have seen someone say put it in 4x4 then put the front on jack stands. Then turn one tire and if the other moves it's engaged.
Just to beat canman to the punch. I'll go ahead and recommend locking the fork over. Really simple and you won't hve to worry about vacuum engaging or not. Do a search for all the details though. Good luck
4x4JB is offline
post #4 of 10 Old 05-29-2012, 09:10 PM
Xpress
You really only have to put one wheel in the air. If it doesn't turn then the axle is locked.
All about that unibody life.
Xpress is offline
post #5 of 10 Old 05-29-2012, 09:48 PM
dancytron
dancytron is offline
post #6 of 10 Old 05-29-2012, 09:55 PM
Anticanman
RIP one good jeeper
Anticanman's Avatar
I wasn't going to post at all but since you called me out.
Goal:
Luck Favours The Prepared
Anticanman is offline
post #7 of 10 Old 06-06-2012, 04:03 PM Thread Starter
01roadking
Thanks for info. jacked up one front tire, in 4 wheel the tire might turn 3 or 4 revs and then lock. Turn the tire the other direction and it might turn and not lock or it might lock after a few turns. but when testing on the hill the front does not lock.> Is the 4-wheel sensor on the front axle, meaning if the lights for 4-wheel come on, it is getting vacume??
post #8 of 10 Old 06-06-2012, 08:18 PM
Anticanman
RIP one good jeeper
Anticanman's Avatar
The vacuum systems fail. It's best to open up the Central Axle Disconnect located on the passenger side of the axle and lock the fork over with the eclip configuration pictured above. It's fast, free and completely reversible. It will solve your problem once and for all.
post #9 of 10 Old 06-06-2012, 09:14 PM Thread Starter
01roadking
Once you lock the fork over you then have to install free wheeling hubs, correct? Or, if the fork is locked in the 4-wheel position that would mean the front wheels would be locked together and the front drive shaft would allways be turning, even though the transfer is not engaged? I removed the fork housing today and the fork moves slowly when I shift from 4-wheel to rear only. meaning the vacume system seems to work. But when testing on a gravel hill the front tires do not spin in 4-wheel. With the left front off the ground it seems to lock in, but I do not feel it is a hard enough engagement to not slip out when under load?? Could there be another problem? I thank you for any help you can give me!
post #10 of 10 Old 06-06-2012, 09:19 PM
Anticanman
RIP one good jeeper
Anticanman's Avatar
You may have to get your driveline balanced, which isnt a big deal. Switching over the hubs on the other hand is quite a financial commitment.
4 wheel drive wont engage.. please help brokenwrangler YJ Wrangler Technical Forum 2 03-30-2010 09:11 PM
Four Wheel Drive Will Not Engage Please Help mulcahy2713 YJ Wrangler Technical Forum 3 05-08-2009 09:56 PM
4 wheel drive will not engage cfuzz1 YJ Wrangler Technical Forum 5 12-29-2008 09:30 AM
4 Wheel drive will not engage Richdog78 YJ Wrangler Technical Forum 2 11-17-2008 04:52 PM
How to engage 4 wheel drive? purplewindworm TJ Wrangler Technical Forum 11 09-19-2006 03:26 PM
