Vacuum Disconnect Problems - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > Vacuum Disconnect Problems
The Original 3/8" Ruffstuff Diff Cover!Ruffstuff Axle Simple Swap Kit!The Ruffstuff NOT Universal 4 Link Kit!
Unread 01-12-2008, 10:28 PM   #1
Alabamaranger
87 Jeep YJ. The end hose (2WD)and the top hose (4WD) has vacuum when placed in 2WD and 4WD. This part works.
The problem is the disconnect only moves when the far end hose is off. I pull this end hose off and tried to blow in it. It seems stopped up. Is this suppose to be a vent hose? The 4x4 light does not work either.
Alabamaranger is offline   Reply With Quote Quick reply to this message
Unread 01-12-2008, 11:16 PM   #2
sentinal02
H2 Recovery Team Member
sentinal02's Avatar
the 3rd hose runs to the vacuum switch on the fire wall and is what turns the 4wd light on. kinda sounds like you've got vac on both ports instead of one at a time depending on which range you want. if that's the case, it's probably the vac switch on the t-case causing the problem.
RIP: '88 YJ 2.5L Ax-5 NP231
Posi-Loked. Herculined. Optima yellow top. 1" Shackle, 2" BDS. Cragar 397's Aussie front.
92 YJ 4.0L Ax-15 231
5" springs, 1" shackle 31's or 35's depending on my mood
sentinal02 is offline   Reply With Quote Quick reply to this message
Unread 01-12-2008, 11:22 PM   #3
Richmond88yj
Eat, Sleep, Jeep
Richmond88yj's Avatar
Blue hose should be the vent hose.
Richmond88yj is offline   Reply With Quote Quick reply to this message
Unread 01-12-2008, 11:35 PM   #4
Alabamaranger
All hoses are black. So the third hose gets it vacuum from the second hose that pulls the ford to lock the axles?
Unread 01-13-2008, 12:09 AM   #5
jbolty
jbolty's Avatar
x2. blue plastic type line from the x-fer case is not to be connected to anything. It's a common mistake to plug it into a vacuum line because it looks like it should go somewhere. Result is either the disconnect won't work or the 4wd light won't work or both.
If you live within wheeling distance of San Diego county, click here
jbolty is offline   Reply With Quote Quick reply to this message
Unread 01-13-2008, 03:21 PM   #6
Alabamaranger
I looked at it today. 3 tubes going to the disconnect form the TC switch. One going in the TC switch form the vacuum source. No lines going to the 4x4 light switch device. I guess someone swapped all the hoses. I wonder if the far end line suppose to be the vent line and a new hose going from the far end connection to the 4x4 switch?
Unread 01-13-2008, 03:38 PM   #7
ctm
alabama didn't you get your answer already on JU?
ctm is offline   Reply With Quote Quick reply to this message
Unread 02-04-2010, 03:25 PM   #8
Red91xj26
get the vacuum disconnect out of here what a horrible feature i have it on my xj and i'm having the exact same problems...
91 Jeep Cherokee Laredo (Ruby) My Build Thread http://www.jeepforum.com/forum/f22/my-91-jeep-xj-laredo-998423/
00 Jeep Cherokee Sport (UnNamed) Build thread soon.
Red91xj26 is offline   Reply With Quote Quick reply to this message
