Vacuum diagrams - JeepForum.com
post #1 of 9 Old 09-09-2013, 02:37 PM Thread Starter
scottmmb
1987 YJ Wrangler
Vacuum diagrams
I recently dropped a 4.2 from a 78 cj5 in my 87 yj. The vacuum lines worry me. Also need to know if there will be any wiring problems
scottmmb is offline
post #2 of 9 Old 09-09-2013, 02:39 PM
dancytron
Probably ought to post on the CJ forum.
This will tell you what was in the YJ. http://home.sprynet.com/~dale02/list.htm
dancytron is offline
post #3 of 9 Old 09-10-2013, 09:45 AM
Que89YJ
Look the nutter bypass and vacuum lines. That is the configuration you want.
Fault codes:
Mean Max pics of everything:
No Start:
Que89YJ is offline
post #4 of 9 Old 09-10-2013, 11:08 AM
superj
where do you live? what type of emissions do they do in your area? if no emissions inspections, run the lines like an old cj. thats how my 87 is ran. zero problems
I don't feel like working on anything at this time so i sold my yj.
superj is offline
post #5 of 9 Old 09-10-2013, 12:19 PM Thread Starter
scottmmb
1987 YJ Wrangler
Ohio. Already took the pollution pump off so that eliminated most of the uneccesary crap
scottmmb is offline
post #6 of 9 Old 09-10-2013, 01:27 PM
Que89YJ
You need the nutter setup for sure.
Fault codes:
No Start:
Que89YJ is offline
post #7 of 9 Old 09-12-2013, 09:41 AM Thread Starter
scottmmb
1987 YJ Wrangler
Which is?
scottmmb is offline
post #8 of 9 Old 09-12-2013, 10:21 AM
dancytron
He is talking about the Nutter bypass. What most of us do instead of making all the emissions stuff actually work is bypass the computer and then set the engine up to run like a 1978 or so Jeep. You've just gone the extra step of actually replacing the whole engine instead of changing a couple of wires and then taking a lot of stuff off. http://www.jeepforum.com/forum/f8/ho...bypass-522262/ http://home.sprynet.com/~dale02/ignmods.htm
I think a 1978 Factory Service manual is going to be the place to find what you want to know.
post #9 of 9 Old 09-12-2013, 10:35 AM Thread Starter
scottmmb
1987 YJ Wrangler
Well the only emissions devices on it are a pump and the egr. I did away with the pump and ill just keep the egr. There's only a couple hoses left. On is off the back of the t on the valve cover. Don't know where it goes. And there are some small ones below the battery
scottmmb is offline
