Vacuum Diagram - JeepForum.com
post #1 of 12 Old 02-09-2009, 05:40 AM Thread Starter
jsl3824
Vacuum Diagram
Can any help me find a vacuum diagram. problem now is front drive shaft moves but I think front axle is not engaged. i replaced the the vacuum shift motor on front axle when i relpaced the t-case. and my dash indicator still is not lighting up when in 4 wheel drive.
jsl3824 is offline
post #2 of 12 Old 02-09-2009, 08:05 AM
Blazin Den
look on 2nd page here
http://www.jeepforum.com/forum/f12/frequently-asked-questions-faq-your-answers-usually-here-451154/
and this one might help also.
http://www.jeepforum.com/forum/showt...ght=shift+fork
http://www.jeepforum.com/forum/f12/front-axle-not-engaging-670260/
95 White YJ 2.5L/AX-5 Stock on 31s. Ground Pounder Fab (BESRK) Front Bumper, Herculined Interior, Windshield/Front Bumper Mounted Lights, Uniden PRO 520XL Cb,Hidden Hitch Trailer Hitch, Bestop Supertop, Modified CJ7 Hardtop and CJ7 Twist Handle Full Doors (winter)
Blazin Den is offline
post #3 of 12 Old 02-09-2009, 08:07 AM
kloppk
Here are a couple...
kloppk is offline
post #4 of 12 Old 02-09-2009, 08:13 AM
kloppk
Originally Posted by Blazin Den View Post
That diagram on page 2 is not correct. It's labeled incorrectly. It's only applicable thru 1990 (not 1995).
In 1991 the switch that causes the 4WD light to go on was changed from a vacuum operated switch on the firewall to a mechanical switch on the vac disco housing. Additionally the 91 and up YJ's only had two vacuum lines going to the front axle as opposed to the 3 vacuum lines used from 87-90.
kloppk is offline
post #5 of 12 Old 02-09-2009, 08:40 AM
Gyerr
I have a 1991 YJ that is exactly as pictured in the diagram. The thing is, the labels on the jeep itself state it was manufactured in late 1990, in Ontario, but the registration states 1991. (Really annoying)
Gyerr is offline
post #6 of 12 Old 02-09-2009, 09:21 AM
rustywrangler
Got my eye on you.....
rustywrangler's Avatar
Thankyou for pointing this out. I will correct that.
Edit: corrected the FAQ, what do you think???
Congenital Heart Disease is a reality for me, BOTH of my children have it. Please read up and become aware for future generations
Lydia Ann-Acquired 08/05/05 Open Heart surgery 08/10/05
Jacob Patrick-Acquired 01/17/08 Open Heart surgery 02/15/08
rustywrangler is offline
post #7 of 12 Old 02-09-2009, 10:04 AM
kloppk
Thank you for correcting the original heading and adding the new diagram.
Looks great!
kloppk is offline
post #8 of 12 Old 12-23-2009, 10:41 PM
Bfraley
I have another question for you guys. I cut my vacuum lines replacing the floor board on the passenger side. I spliced them all back together and my 4WD works. When in 4WD High the light (light on top) works, when in 4WD Low the same light stays on (light on top), the 4WD Low light does not turn on, the 4WD High light (light on top) stays on. Any Ideas?
Bfraley is offline
post #9 of 12 Old 12-24-2009, 09:09 AM
Tshark299
Tshark299's Avatar
1987 YJ Wrangler
Mine only has one 4WD light that comes on when the axle locks. Do the later YJs have separate lights for 4WD High and Low?
- 4.0L, AX-15, NP231, 4.10s: 3.5" BDS, 31" Muds
- Donated drive train to the YJ, Parted out the rest
- Buick 225 V6: Painless Wiring Harness, Warn Overdrive & Hubs, 2" Lift, 31" Muds
Tshark299 is offline
post #10 of 12 Old 12-24-2009, 06:51 PM
MJMPC
I thought mine only had one in it also .
MIKE
MJM Powder Coating
Elizabethtown Ky.
MJMPC is offline
post #11 of 12 Old 12-24-2009, 07:15 PM
jeepdrvr101
I do not think it can differentiate between 4 hi, or 4 low, if so, you would need an additional switch an the transfer, right?
89 YJ Islander, White with blue pearl custom paint, 4.2 Nuttered, Holley carb, Light bar W/4 Kc daylighters, 32x11.50r15, Unknown lift, kenwood sound, Rockford fosgate Amp x2, Kicker Amp(1)
A work in progress...
2006 Ram 1500 TRX4 5.7 HEMI All stock
jeepdrvr101 is offline
post #12 of 12 Old 07-23-2013, 09:13 AM
juratstamp
vacuum diagram needed for 99 tj 4 cyl
I Have an open port right of brake booster hose.
juratstamp is offline
anyone have a vacuum diagram or pic from an 87/88 yj 4.2L? cueball YJ Wrangler Technical Forum 10 02-09-2012 07:54 AM
Vacuum Diagram roundedge4lfe YJ Wrangler Technical Forum 3 06-17-2007 11:46 PM
Vacuum diagram soxfann YJ Wrangler Technical Forum 8 11-11-2004 02:08 PM
Anybody have a vacuum diagram for a 2.5? drew2000 YJ Wrangler Technical Forum 2 12-21-2003 01:50 PM
vacuum diagram Durbahn YJ Wrangler Technical Forum 9 06-04-2003 09:56 PM
