vacume lines after nutter bypass - JeepForum.com
post #1 of 8 Old 04-12-2009, 08:16 PM Thread Starter
lancer27
ok so i did the nutter and i want to rip all those nasty usless lines out. but i dont know what ones i need and idk where to cap them off at. so a little insight maybe some pics would be great. and also i dont get a whole lot of pull on the distributer cap vac line. is that a problem?
97 tj i6 3.5 RE superflex lift. hp dana 30 4.56 gears ausie up front. dana 44 33spline alloy usa shafts arb rear. tom woods supper short sye and matching cv ds. 35x12.50x15 goodyear MTR's with kevlar. york OBA system. Metal Cloak High Arch tube fenders!(my favorit mod!!!)
lancer27 is offline
post #2 of 8 Old 04-12-2009, 08:25 PM
Tompatt
Tompatt's Avatar
1987 YJ Wrangler
Heres something to look at http://www.jeepforum.com/forum/f12/vac-line-clean-up-post-nutter-post-weber-well-now-677814/
also.. what kind of carb you have? did you move your vac line that goes from Dist to carb to the other port?
Thomas
-1987 YJ
Tompatt is online now
post #3 of 8 Old 04-12-2009, 08:27 PM
buckshot500
Hold on there now just a minute!
Some of that stuff is important.
The charcoal canister & all the lines connected to it.
The CTO switch & it's lines.
The EGR
The intake manifold heater.
The manifold vacuum going through the firewall, is for the cabin heater/AC
There are more items too, you really need to know & understand any wires or vac lines you are going to cut out.
For instance, the side of the battery tray has two relays & a plastic box with resistors in it. Cut those & you won't have electric choke, intake heater,(important) & the box is for the sol-vac & the rear window defroster.
Whatever you do, don't cut the resistance wire in the engine compartment loom.
Much of that emissions crap can come out, but you need to research it till you are positive.
buckshot500 is offline
post #4 of 8 Old 04-12-2009, 08:28 PM
Tompatt
Tompatt's Avatar
1987 YJ Wrangler
The EGR
for learning about what each thing does... look here.. http://home.sprynet.com/~dale02/list.htm
Thomas
-1987 YJ
post #5 of 8 Old 04-12-2009, 08:29 PM
rustywrangler
Got my eye on you.....
rustywrangler's Avatar
The link Tompatt posted in his first post above covers everything you need to do and keep those items above.
Congenital Heart Disease is a reality for me, BOTH of my children have it. Please read up and become aware for future generations
Lydia Ann-Acquired 08/05/05 Open Heart surgery 08/10/05
Jacob Patrick-Acquired 01/17/08 Open Heart surgery 02/15/08
rustywrangler is offline
post #6 of 8 Old 04-12-2009, 08:34 PM
Tompatt
Tompatt's Avatar
1987 YJ Wrangler
gettin quicker in replies ay rusty? haha. before this site.. i would still be running the WORST vac set up ever seen on JF. haha.
Thomas
-1987 YJ
post #7 of 8 Old 04-12-2009, 08:44 PM
buckshot500
If the distributor vacuum line is connected to a timed port like it should be, then it's not gonna pull much at idle. Connect a gauge to it & increase the rpms to see if it gets more vacuum.
Edit; Tompatt's links are good!
I would suggest leaving the intake heater though, it really helps on a cold morning.
post #8 of 8 Old 04-12-2009, 08:48 PM Thread Starter
lancer27
ok thanks for the quick response. i am running the carter pos. and yes i have moved the lines around using the t split. and thats y i came here cuz i know i can pull out some of the usless wireing but i dont know which ones i should and shouldnt touch. but it just dosnt seem to have any affect on the idle if i pull the vac. line off from the dis cap and leave it open. i would think it might change something. i may be wrong. but thats y i come to jf
lancer27 is offline
"Nutter" Bypass!! Vacuum Lines?? turfman* YJ Wrangler Technical Forum 17 03-27-2017 05:04 PM
2.5l vacume lines....help please moerawn YJ Wrangler Technical Forum 2 10-18-2006 07:35 AM
Vacume lines 95yjed YJ Wrangler Technical Forum 2 12-04-2005 08:03 PM
Nutter & Vacume Advance??? RabiDaWise YJ Wrangler Technical Forum 11 02-23-2005 08:10 AM
Vacume lines.. UGH!!! dirtsurfr YJ Wrangler Technical Forum 7 07-21-2004 07:46 PM
