vaccum actuator swap - JeepForum.com
post #1 of 2 Old 11-05-2011, 12:45 PM Thread Starter
corusahara
hello everyone.
I am putting in a 4.10 geared dana 30 to match the gearing in my recently installed 8.8 and it seems the vacuum actuators are different. my jeep is a 94 and the dana 30 i'm installing is an 89.
My question is, can i simply take off the vacuum actuator from the axle i'm removing and install it onto the axle i'll be putting in so that all the connections stay the same? i've already removed the actuators from both axles and all the internal dimensions look the same.
thanks in advance for any feedback!
Matt
corusahara is offline
post #2 of 2 Old 11-05-2011, 01:44 PM
wanabejeeper
1987 YJ Wrangler
Pretty much yes... The difference really is the electrical connection for the 4wd indicator is on the axle on newer jeeps. On older ones its on the firewall.
87 YJ The Original!
It goes in that barrel you wheel out to the street once a week.
My build thread
wanabejeeper is offline
eliminating vaccum actuator sitdwnandhngon YJ Wrangler Technical Forum 2 01-10-2008 07:46 PM
TJ shaft swap. Where do I get the block off plate for the vaccum actuator? jnkyrdg04 YJ Wrangler Technical Forum 4 08-19-2007 08:34 AM
Vaccum map Tim3852 YJ Wrangler Technical Forum 16 10-19-2006 08:37 AM
4wd vaccum nightstalker5.0 YJ Wrangler Technical Forum 2 09-21-2004 03:16 AM
4 x 4 vaccum talley1147 YJ Wrangler Technical Forum 2 08-13-2004 01:41 PM
