Vac Lines - JeepForum.com
post #1 of 10 Old 06-24-2002, 06:33 PM Thread Starter
BrandonParvin
Vac Lines
I believe that it is 6 vac lines total for my 4wd. Unfortunately i cannot afford a locker at this time, but I still wouldnt mind having my 4wd back. If anybody can tell me what size vac line i need, and roughly how many feet i would greatly appreciate it.
94YJ Sony Sound System
31x10.5 BFG All-Terrain
Flowmaster 40 series muffler
3in Performance Accessories Body Lift
BrandonParvin is offline
post #2 of 10 Old 06-24-2002, 06:38 PM
AllanAlxndr
</font><blockquote><font size="1" face="Verdana, Arial">quote:</font><hr /><font size="2" face="Verdana, Arial">Originally posted by BrandonParvin:
<strong>I believe that it is 6 vac lines total for my 4wd. Unfortunately i cannot afford a locker at this time, but I still wouldnt mind having my 4wd back. If anybody can tell me what size vac line i need, and roughly how many feet i would greatly appreciate it.</strong></font><hr /></blockquote><font size="2" face="Verdana, Arial">Hey Brandon,
When I get home from work tonight I will look, I think they should be the same...
Allan
***What do I know, I just cause Problems***
*'90 Wrangler*
*4 Banger*
*6" of lift, (4" suspension, 2" body)*
*33" ATs on Outlaw II's*
*Pioneer DEH3500/CD deck*
*1800WATT Amp w/ Custom Box*
*2 - 8" Rockford Fosgate HEs*
*Cobra 18WXSTII w/ 4' Firestik Antenna*
Member of
AllanAlxndr is offline
post #3 of 10 Old 06-24-2002, 06:39 PM
Plink
Plink's Avatar
<a href="http://www.jeepforum.com/ubb/ultimatebb.php?ubb=get_topic;f=7;t=000457" target="_blank">http://www.jeepforum.com/ubb/ultimatebb.php?ubb=get_topic;f=7;t=000457</a>
Try that link lots of info
87 YJ 4.2
2" BL, 2" Shackle, 1.5" Black Diamond and Junk
31 MTRs on MOABs
Need new front and rear bumpers
HAM: KB3JQS
Plink is offline
post #4 of 10 Old 06-24-2002, 07:52 PM
Bob K
Bob K's Avatar
The vacuum harness from Jeep is a little bit $$$, but probably the most reliable way to fix. Lockers won't fix it, a cable loc will.
'87 Wrangler YJ 4.2 I6 (sorry, sold)
JuiceBox ignition
2 1/2" ProComp Lift
31" BFG A/T's
K&N Filter
Custom Rock Guards
Turbo Muffler
Rear Track Bar in the shed
Other Tricks I won't tell to just anybody!
'99 Grand Cherokee 4.7 V8
Towing Package
K&N FIPK
ProComp MX6 shocks
Borla Exhaust
Tow Hooks
Alpine CD with Infinity+iPod connect
Just getting started!
If you're not living on the edge...
you're taking up too much space.
Bob K is offline
post #5 of 10 Old 06-24-2002, 08:24 PM
AllanAlxndr
What I am wondering is can you just re-run vac lines in the exsisting one... My Battery leaked on mine and toasted them...
Allan
*'90 Wrangler*
*4 Banger*
Member of
post #6 of 10 Old 06-24-2002, 08:43 PM
johny1i
johny1i's Avatar
Yes, you can patch them in, I had to do that a few months ago because mine got too close to the exhaust and it melted the little plastic tubes. Just pick up some of the small (5/16" I believe) rubber vacuum hose and slide it over the ends of the plastic lines after you cut out the bad section. Mine works fine--
Currently an '86 CJ-7 and a '77 CJ-7 Golden Eagle---#4 and 5 following a '01 Sahara, '90 Sahara, and '85 CJ-7....
johny1i is offline
post #7 of 10 Old 06-24-2002, 09:11 PM Thread Starter
BrandonParvin
Sweeeeeeet. Hey allan if you get some time tonite i am going to work on mine. If you want maybe we could do yours to. Let me know what you think.
post #8 of 10 Old 06-24-2002, 09:16 PM
AllanAlxndr
<strong>Sweeeeeeet. Hey allan if you get some time tonite i am going to work on mine. If you want maybe we could do yours to. Let me know what you think.</strong></font><hr /></blockquote><font size="2" face="Verdana, Arial">Let me know how it goes... During the week probably wouldn't work for me but the weekend might be a possiblility unless something comes up... I still need to get all of my stuff too.
I looked at my lines and I only have 4 (2-yellow, and 2-green) I believe.
Allan
*'90 Wrangler*
*4 Banger*
Member of
post #9 of 10 Old 06-24-2002, 09:55 PM
AllanAlxndr
Also Brandon,
Did you call anywhere to see if anyone carried the whole assembly... I called Checker and he told me that I would probably have to call the dealership or an off road shop... I think I might buy the Posi-lok and say screw the whole vacuum setup. After inspecting my lines closer, They are totally shot, I will have to start completely over. There is no way I can do patch work on it...
Allan
*'90 Wrangler*
*4 Banger*
Member of
post #10 of 10 Old 06-25-2002, 01:01 AM
bigjeep39
bigjeep39's Avatar
<img src="http://www.binaryinc.org/images/jeep/jeep_vac_diagram.jpg" alt="" />
1998 TJ
Slow steady project.
bigjeep39 is offline
what lines are these on my 4.2 and why PASKS YJ Wrangler Technical Forum 8 08-06-2009 11:38 AM
Hard Brake lines(not soft lines) Nonya TJ Wrangler Technical Forum 0 09-04-2007 06:33 PM
Vac. lines Josephrk24 YJ Wrangler Technical Forum 5 10-12-2006 11:51 AM
what are these lines 01rc51 TJ Wrangler Technical Forum 6 06-19-2006 06:15 AM
Need braided steel fuel lines (from tank to frame lines) drew2000 YJ Wrangler Technical Forum 4 06-18-2006 08:38 AM
