V8 Wrangler - JeepForum.com
post #1 of 3 Old 12-21-2001, 09:22 AM Thread Starter
Gper4life
V8 Wrangler
I want to put a v8 in my 89 yj 4.2 but I want to keep it simple. If I go with an amc motor then I don't have to change my tranny or bell housing. I was wondering what a good v8 would be to put in without cutting my motor mounts out. I am looking for a bolt in v8 that won't tear an ax 15 all to pieces. I do some medium off roading and I know that my tranny won't last too much longer anyway(206000 miles). Any suggestions?
89 YJ upgraded with 95 Chevy LT1 small block, NV4500 5spd, tera low 231 SYE, Custom built crossmembers and skids, 2003 Corvette Electron Blue paint, 3 inch custom spring lift with 2 inch shackles, 2 inch body lift, locked 8.8 with discs, 4:10's and 35's, spray lined tub, and a few other unmentionables
Gper4life is offline
post #2 of 3 Old 12-21-2001, 09:44 AM
glm 87 wrangler
Advanced adaptors would be able to handle this for ya.Give them a call or email you could put a 350 with a bolt on motor mount rig.I bidded on one but lost for a adaptor to a 999 or 727 tranny and a 350 bolt on motor mount bracket so i know there out there.But staying with my 258 because the mods i done makes it perform strong.Your ax15 tranny i know little about though,but im sure they make an adaptor for it.later
Gary 87 Wrangler 4.2 258 with weber carb and TFI upgrade.
31/10.5 and Nutter bypass!
glm 87 wrangler is offline
post #3 of 3 Old 12-23-2001, 08:17 PM
jeeping18
i have a friend that dropped a AMC 360 into a CJ7 and it fits great and runs awsome, he still has the stock 5 speed but im not sure what it is. i am also looking a putting a 351 winser in my yj if anyone has any info i would appreciate it!! thanks
1991 YJ
-4.0L I6
- BORLA CAT BACK EXAUST
-2.5 INCH PRO-COMP LIFT
-31X10.50 PRO-COMP MUD'S
-15X8 EAGLE ALLOYS
-3:73 gears
also a 2000 TJ
jeeping18 is offline
Trade 05' Wrangler X and $1000 for 05' Wrangler Unlimited? GMBNT42 TJ Wrangler Technical Forum 28 03-13-2009 09:48 AM
Will an 05 Wrangler Unlimited 44's bolt into a 99 wrangler? oneslowz28 TJ Wrangler Technical Forum 11 01-08-2009 02:06 PM
Turn a 1997 Wrangler into a 2006 Wrangler MeSoDumm TJ Wrangler Technical Forum 14 06-25-2008 10:24 PM
Will a 1989 Wrangler Full steel door/hard top fit on a 1995 Wrangler alandchris YJ Wrangler Technical Forum 2 03-13-2007 04:51 PM
Using a Soft-Top From a 2000 Wrangler on a 1998 Wrangler? Nighthawk TJ Wrangler Technical Forum 3 06-05-2002 06:02 PM
