V8 versus I6 oil Press Gage Wiring - JeepForum.com
post #1 of 1 Old 05-14-2002, 02:56 AM Thread Starter
highway jeeper
I am doing a V8 305 swap to remove my 4.2 258.
On the 4.2 there was only one wire connection / connector for the oil pressure hook-up, but on the Chevy 3o5 I see that under the oil filter the electrical connection has two quick connect terminals.
Can anyone tell me how I hook this up? I am guessing that I just hook my existing single wire onto one terminal on the chevy and then for the other terminal just connect it to ground (I was thinking to run it to the block)
Need help please.
highway jeeper is offline
Problems with dash oil gage might change to pressure gage instead of sending unit cornfield25 TJ Wrangler Technical Forum 2 07-04-2008 06:04 PM
gas gage hepcat75 YJ Wrangler Technical Forum 6 08-14-2007 11:52 PM
Help with 87 YJ gas gage 87yjjeep YJ Wrangler Technical Forum 1 04-23-2007 06:07 PM
gas gage onemoredrinkk TJ Wrangler Technical Forum 1 03-05-2007 09:03 AM
HFT U-Joint Press versus BFH edzakory TJ Wrangler Technical Forum 7 12-14-2006 08:29 PM
