V8 swap thread. trying to ditch the ECU - JeepForum.com
post #1 of 16 Old 09-04-2013, 05:46 PM Thread Starter
Fellows45
Hi all,
I just picked up a rebuilt ax15 for my v8 swap! now i'm off to look for a motor.
I had a few questions about motors to put into her.
(since i'm trying to ditch the ecu, also the only wiring I want is to the gauges and Radio) what motors will drop right in and run off a good old-fashioned carb and ignition? do the AMC 273/318/340/360 V8's fit the bill? if not Ive heard some of the chevy, GM, and for V8's might also work.
Help is greatly appreciated and I will also be starting my own build thread soon!
Thanks so much all ,
Fellows!
Fellows45 is offline
post #2 of 16 Old 09-04-2013, 08:12 PM Thread Starter
Fellows45
bump!
post #3 of 16 Old 09-04-2013, 08:21 PM
captainauti
what are you looking for in the end. whats your budget? what motors are you familiar with working on? personally, id do a 5.7, carbed, with a yl breakerless mallory distributor. least amount of wiring. or find a complete marine 350 carburated. i put a marine in my jeep and in a malibu. you can find them fairly cheap, and are very basic, no emissions, and no government bs. and the build hp all the way up the rpm band.
_______________________
Capt. Nate
aka Scallywag
95 yj 4.3 vortec csfi, 4l60e/np231cj (scallywag)
1973 Wagoneer (honey wagon)
2013 Escape titanium 4wd ecoboost
2011 F150 4x4 5.0 Coyote SVT Supercrew
2008 E450 v10 Jayco Greyhawk 28 (tildah)
captainauti is offline
post #4 of 16 Old 09-04-2013, 08:29 PM Thread Starter
Fellows45
My budget is 1500. And that doesn't include what I sell my 2.5 and ax-5 for.
I Just want an engine that is really basic and has minimal wiring.
does the 5.7 have a computer? and are there any specific years that it came out of?
And as for a marine engine, I dont know much info about them, I just want to make sure I can find a bell housing for whatever engine I do end up getting.
I am just trying to find a simple v8
post #5 of 16 Old 09-04-2013, 08:38 PM
JeepinJeremy
good luck no way 1500 bucks is enough for this swap. Keep your jeep as is or sell it and buy one already converted.
JeepinJeremy is offline
post #6 of 16 Old 09-04-2013, 08:59 PM Thread Starter
Fellows45
I guess your right, alright ill just have to put 3000 in for the swap and do it right, I was going to try an go cheaper, like trying to find a decent junkyard motor.
Now where does that put me?
post #7 of 16 Old 09-04-2013, 09:18 PM
4wheelex
Just started my v8 swap.. I found a whole doner truck drove it on my trailer for $ 400.. It was a ford w/ 302 and auto. I bought the adapter kit from advanced adapter and my t case bolted right to the tranny ( which was rebuilt using the the tail shaft adapter and output shaft from the kit).. I went through the engine, and done some minor modifying. The kit also came with engine to frame mounts(weld on) and inside the frame headers. Using a Mallory dizzy and a gm style one wire alternator. Should be a very clean installation.. The 302, c4 tranny and np231 as a package is 8" shorter than the 6 banger set up and will set the engine 1 1/2 inches farther forward from the firewall.. Ford chevy dodge I have no preference but I have tons of sbf stuff (love my stangs as much as the jeep) that's why I went sbf having a whole doner vehicle has been nice and I don't plan to get rid of it until I'm done with the swap.. But watch your dollars depending on what your wantin in the end is how much you are gonna spend.. So far I'm about 3800.. And that's not including the axles or suspension that I have installed getting ready for this swap!! Good luck and keep us posted!!
Sent from my portable office
4wheelex is offline
post #8 of 16 Old 09-04-2013, 09:55 PM
czjeeper
OP those are MOPAR engines! Not AMC.
US Army combat vet
2011 Grand Cherokee Laredo 3.6
Armed Forces Jeeps Member #125
Red Jeep Club Member #251
In the Portland/Vancouver area? Check 'em out!
czjeeper is offline
post #9 of 16 Old 09-05-2013, 04:50 AM
jay-h
My understanding is that the block dimensions of the 273/318 etc family make them harder to put into a small space than, say a small block Ford
This is one of the reasons the Sunbeam Tiger had a Ford engine even though Rootes was acquired by Chrysler.
My toys
'89 Wrangler YJ
'47 CJ2-A
wife's toys
97 Grand Cherokee (ZJ)
87 MB 560SL roadster
jay-h is offline
post #10 of 16 Old 09-05-2013, 06:42 AM
captainauti
go to junk yard, get a pre vortec 5.7, maybe $400, strip off all fuel and electrical to bare long block, leaving your tin. add edelbrock intake, 4bbl carb with mechanical choke, add mallory ylm distributer, only has 3 wires to it, one ground, one +, and one off the (-) on the coil. no vacuum, all centrifugal. use a one wire alt, and you have minimal wiring. then of course you need starter circuit, and guages. but very minimal. pm me if you want a schematic. i have one here.
Capt. Nate
aka Scallywag
post #11 of 16 Old 09-05-2013, 07:08 AM
czjeeper
Not at all true.
There has been a large amount of Jeepers putting the Dodge/Jeep 5.2/5.9 in YJ's recently.
They fit just fine, without any issues.
US Army combat vet
czjeeper is offline
post #12 of 16 Old 09-05-2013, 09:09 AM
87TPIYJ
87TPIYJ's Avatar
1987 YJ Wrangler
SBC's has been done 1000 times and parts are a dime a dosen. I vote a Chevy 350 aka 5.7L.
YJ 350TPI NV4500 HPD60 14BFF ARB Chromo's
March 2017 YJOTM
87TPIYJ is online now
post #13 of 16 Old 09-05-2013, 09:10 AM
Xpress
Originally Posted by czjeeper View Post
Not at all true.
This. More than enough room in there to fit either the 5.2 or 5.9 more than comfortably.
All about that unibody life.
Xpress is offline
post #14 of 16 Old 09-05-2013, 09:38 AM
SeanB95YJ
yes... heck I've seen motors put into YJs that I NEVER would have thought would fit.... 6BT, Dodge V-10, Big block chevy's, etc.
the only thing I haven't seen (tho there's probably SOMEONE out there who has) is a Hemi.... and I mean a REAL Hemi (AKA the huge mopar powerhouse )
Sean B. - Schenectady, NY - 95 YJ, 350/700r4/NP241, JB Shorty SYE, 8.8 rear, 2" BDS, 1" homebrew shackles, Daystar 1" BL, TJ flares, 35x12.50 General Grabber AT2 on 15x10 Bart D-Truckers, Polyshield polycarbonate windshield, HD over/under crossover steering
swap/build thread:
SeanB95YJ is offline
post #15 of 16 Old 09-06-2013, 05:33 AM
bogleparsons
HEMI smemi, I want to see a Cummins lol
If it's not supposed to move and does use duct tape.
If it's supposed to move and doesn't use WD40
bogleparsons is offline
engine swap , swap , swapping
