v8 swap into 4 cylinder YJ - JeepForum.com
post #1 of 8 Old 07-30-2001, 03:31 AM Thread Starter
JerzyJeep
a friend was about to pick up a 4 cylinder 5 speed with a blowm motor for real cheep ..he wants to know if the 4banger trans is the same as the 6 cylinder trans? ..also we wanted to drop in a chevy smallblock ..will the 4 cylinder trans hold up ?
Craig TOURSO
new project CJ5
who needs a roof ?
JerzyJeep is offline
post #2 of 8 Old 08-24-2001, 12:11 PM
MKB
They 6 cyl has the AX-15 tranny. It will work with most applicatoins unless you plan on using 38" + tires. The 4 bangers came with a AX-5 tranny (they are complete junk, replaced with a AX-15 and adaptor from AA).
94 YJ 2.5, 5 spd
PerformanceAid Throttle Spacer
K&N w/ Turbo Tube
Swaybar Disco's
2.5" Spring Lift w/1.25" HD Shackle
1" Body Lift
4.56 gears w/ Rear Detroit Gearless
31x10.5 Nankang Radial A/T
15 to 20 Gal tank conversion
Warn 9000LBS
Dual Batt and 150 Amp Alt
Home-made Front&Read bumpers
Hard & Soft tops
MKB is offline
post #3 of 8 Old 07-27-2009, 01:39 PM
Ben_321
yes i believe the 4cyl will have the AX-5 transmission which is not strong enough for a v8....get a better one.
Ben_321 is offline
post #4 of 8 Old 07-27-2009, 04:44 PM
Tomb Raider
Addicted...
Tomb Raider's Avatar
I'm gonna say this because it hasn't been said......
But if your gonna put a 350 into a YJ.....it's not just the tranny you have to worry about.
Gonna need front springs since the 350 is a couple hundred pounds heavier than the 4banger.
Gonna need to take a look at axles. I never recommend that kind of torque put on the stock jeep axles. My 350....a plain jane TBI setup taken out of a blazer would "chirp" my 42" tires.....locked. You don't want that kind of torque on a stock jeep axle for anything more than driving it down the driveway.
Take a look at novakadapt.com . They have lots of good info on 350 swaps.
Tomb Raider is offline
post #5 of 8 Old 07-27-2009, 06:00 PM
NOVA87Wrangler
1987 YJ Wrangler
Novak is a really good resource for information, but I'll throw in some additional info since I did a swap with them that is just about done. Put a 2005 5.3L into my 87.
Transmission will need to be upgraded. Novak has a good comparison between the options. I was planning on a good number of highway miles on mine so I stuck with the AX15 for the OD and interchangeability. No way an AX5 will hold up and Novak won't even make an adapter for it because of that.
Transfer case will be fine.
Rear axle will be a time bomb, I went with an 8.8 with 4.10's and swapped in a front D30 to match the gear ratio (the 4cyl should already have 4.10's so that's your easiest option.
As for front springs, I did have the 4.2 and the 5.3 I swapped in is lighter than the 4.2. That being said, I ended needing (maybe being more comfortable) a suspension lift to have adequate room for the front d/s and routing the exhaust so I would've needed to replace the springs anyways.
Looking for: half hard doors w/sliders, complete soft top with hardware.
NOVA87Wrangler is offline
post #6 of 8 Old 07-27-2009, 08:54 PM
speepdaedeesi
a sm465 can be bought for around 100-200 bucks... rebuilt i think is around 400 but i cant really remember, and wife is pissed im not in bed.
700r4 are all over the place, and vary in price. best bet is finding a parts chevy truck for a few hundred bucks, take out the motor and trans, and sell it to the junkyard to get a little money back
89 yj stock- sold
92 yj stock- sold
97 tj 2"bb,31" tires- sold
95 yj soa,350 v8,sm465,44" tires,d60,14bolt- sold
95 yj soa,350v8,700r4,35" tires,d30, 8.8, fuel cell- sold
current ride-97 TJ- 86k miles, 4cyl auto, black casinos, 31" BFG A/T
speepdaedeesi is offline
post #7 of 8 Old 04-01-2010, 08:32 PM
AceRABEL
what about cooling, fuel, and other stuff? do you have too change that as well or can you run a 350 with stock parts from a yj?
AceRABEL is offline
post #8 of 8 Old 04-01-2010, 08:43 PM
stu1021
X2 on the advice to find a complete donor vehicle - much easier to swap the engine, tranny, harness, and all related components. I would also look at a S-10 Blazer or Pickup with 4WD. You can transplant the the 4.3L Vortec, a 700R4 or 4L60E and NP231C using just the rear half of your tcase and it's output shaft and you will need no adapters - just engine and tranny mounts. I transplanted the evap system, fuel system, and guages out of my donor vehicle and it made life much easier during the swap. Also, a good shop manual with wiring diagrams for both vehicles is a must. If you must have the V8, then look for an older S10 with the 700R4/231C combo and put that behind your SB and you still get by without the adapters. I will say that I am very happy with the 4.3 in mine though.
'90 YJ Wrangler - 4.3L Chevy
'91 GMC 3500 Bus - Tow Vehicle
'87 MBenz 300D Turbo
'02 MBenz E55 AMG
'55 Piper Apache
stu1021 is offline
6 cylinder swap bob35170 YJ Wrangler Technical Forum 5 03-15-2010 10:34 PM
Jeep Tj 6 cylinder swap freeagent156 TJ Wrangler Technical Forum 1 02-27-2008 09:48 AM
newbie.. need help with 6 cylinder swap Dwayne96 TJ Wrangler Technical Forum 21 02-19-2008 10:10 PM
slave cylinder swap instagator79 YJ Wrangler Technical Forum 4 09-20-2007 09:51 AM
4 cylinder to 6 cylinder swap... senaTTor YJ Wrangler Technical Forum 2 10-25-2006 06:35 PM
