v8 swap help - JeepForum.com
post #1 of 6 Old 05-03-2011, 10:19 AM Thread Starter
tribalwithstyle
v8 swap help
Ok im planning on either a 302 or a 350 into my bucket of blots anyone know if there is w wiring harness for my beast for either of those motors or do u have to use the factory harness.
tribalwithstyle is offline
post #2 of 6 Old 05-03-2011, 10:36 AM
OOXTEME
Not sure if you go TBI but I have a carbed 350 and just left the old harness in it just tied in oil pressure fuel battery and power for the hei
Originally Posted by ZeroGravity View Post
People really drive with the top down and the A/C on??
94 Yj 350 700R4 Swap with Ford 8.8 in progress, 3" BDS Lift, 1" Shackels, 3" Body, Rhino Lined Tub
OOXTEME is offline
post #3 of 6 Old 05-03-2011, 10:43 AM
hesserdude07
x2. carb set up going in. Only need 4 wire to do the whole motor... I have a thread on my SBC questions. Good luck
1993 Silver YJ. SBC 300hp. 700r4. NP231 hybrid. 35" Mud Terrains. 7" Toyota Basterd packs. 8.8 Welded. D30 loc-rite. 1" body lift. 4" LED tails. Custom bumpers. Warn M8000. Hella's. (Trail rig)
hesserdude07 is offline
post #4 of 6 Old 05-04-2011, 10:15 AM Thread Starter
tribalwithstyle
Not going carb this is gonna be a crawler i kinda need fuel injection so i dont run out of fuel on a crazy incline but thx any one else. oh is there any good threads on the swap i herd something about a speed sensor that is adapted to the jeep harness and some other dumb things
post #5 of 6 Old 05-04-2011, 10:32 AM
hesserdude07
yeah i know there are harnesses around. I was going vertec at first but didnt... as to ease for right now! Check out Pirate4x4's jeep section, there are 1000s of write ups. (warning on posts- READ THE NEWBIE STUFF FIRST)
I think painless wiring makes a harness.
I know ive seen couple others...
post #6 of 6 Old 05-04-2011, 11:33 AM
1 ton yj
1 ton yj's Avatar
The engine harness is independent of your Jeep's body harness, so there is no "adapting" to what you have now.
Decide which engine you're going to put in, then figure out the details.
P.S. the wiring is the easy part
1 ton yj is offline
Another 4.0 Swap question...head swap vs. full engine swap Mol YJ Wrangler Technical Forum 11 10-18-2010 04:11 AM
88 4 cyl swap transfer case swap to 89 6 cylinder ? YjShane YJ Wrangler Technical Forum 1 03-26-2010 04:11 PM
Dana 30 diff. swap vs. gear swap BBCAT YJ Wrangler Technical Forum 2 02-28-2009 01:17 PM
HVAC Control Swap: Swap just the lower ac/heater housing, or all of it? Justin Brimm TJ Wrangler Technical Forum 5 12-20-2007 03:29 AM
