v8 swap help - JeepForum.com
post #1 of 5 Old 05-15-2010, 04:21 PM Thread Starter
rap169
v8 swap help
need some help with a v8 swap. Heres the problem. Its an 88 wrangler that was a 6cyl ba-10/5 its a bare frame and im tring to instally my chevy 350 v8 attached to a ax-15. For some crazy reason no matter how much i try to center the engine, the ax15 is offset towrads the passenger side. is this normal? or should the transmission output shaft be centered in the frame? Its hard for me to tell if its right since the skid and mount are from the ba-10. from what ive found on the net the engine should be centered. Is that correct?
rap169 is offline
post #2 of 5 Old 05-15-2010, 06:12 PM
dodger889
It could be off center towards the passenger side an inch or two. To keep the drive line straight. front to back. you will more than likely set the engine over a little to clear your steering any way.
A 89 yj with a 4.0 aw4 sye out of an 92xj. Now the hard part is done time to get it up in the air just a bit. Working on 8.8 with 3.73 and lsd for the rear. and new D30 hp with 3.73 .
For those who have not figured this out I'm old school but can handle the new too.
Originally Posted by bigsquat View Post
im just cheap, and cheap makes you creative.
dodger889 is offline
post #3 of 5 Old 05-15-2010, 06:15 PM
stu1021
On YJ's the D35 pinion is offset slightly to the passenger side so that is correct
'90 YJ Wrangler - 4.3L Chevy
'91 GMC 3500 Bus - Tow Vehicle
'87 MBenz 300D Turbo
'02 MBenz E55 AMG
'55 Piper Apache
stu1021 is offline
post #4 of 5 Old 05-15-2010, 06:50 PM
tbburg
Not sure about stock locations side to side wise, but:
If your engine is centered and the transmission is offset to one side, the transmission mount is offset. This puts the engine/trans in the vehicle crooked.
Doing a swap, pretty much everything is variable, but the power train should be straight in the vehicle. The engine may be offset to one side or the other, but the whole engine/trans/Xfr case assembly has to move, not just the engine. If the crank snout is centered in the frame, then the trans output should also be centered. It may mean you have to fab a trans or Xfr case mount to make it line up but that's what you have to do.
If the stock trans/Xfr case mount has an offset, and you want to keep it in the stock location, then you need to offset the motor to match the offset of the trans.
A lot of motors aren't centered in the frame rails, for a variety of reasons, but they are always straight(parallel) in the frame.
Hope that helps
"Never attribute to malice that which can be adequately explained by stupidity, but don't rule out malice."
My other car is also a Jeep,.. and so is the other one,.. and that one too. How many do you own before it's "a herd" ?
tbburg is offline
post #5 of 5 Old 05-16-2010, 07:02 PM Thread Starter
rap169
thanks everyone. Yeah i thought the same thing that all the the drivetrain should be strait. But i did find somewhere on the net that the stock drivetrain is offset about an inch towards the pass side. so i think im gonna offset the engine to the pass side about 1" and madify the skid plate/trans mount.
rap169 is offline
Another 4.0 Swap question...head swap vs. full engine swap Mol YJ Wrangler Technical Forum 11 10-18-2010 04:11 AM
body swap VS motor swap questions baltimorebiker YJ Wrangler Technical Forum 9 03-29-2010 09:49 PM
Gathering parts for Axle swap, SOA, and V8 swap... tank29 YJ Wrangler Technical Forum 7 12-03-2009 02:42 AM
HVAC Control Swap: Swap just the lower ac/heater housing, or all of it? Justin Brimm TJ Wrangler Technical Forum 5 12-20-2007 03:29 AM
