V8 swap - JeepForum.com
post #1 of 1 Old 03-18-2011, 06:23 AM Thread Starter
marvinb
V8 swap
ok guys im gathering parts for a V8 swap. im gonna do a 305/700r4/231c/j. Im using a 305 cause it was free!!! Even though it was free im in the process of rebuilding it now to freshen everything up, the tranny i have to go pick it up today.. i bought a 231c out of a s10 blazer and got the 700r4 adapter from that rig so i could bolt all that stuff up without costly adapters..
To build the t-case using 231c and 231j ive read on here that i need to use the front half of the "c" and the back half Of the "j".. so im gonna ask, do i use the "j" main shaft in the "c" with the "c" gears for the rear drive shaft side and the "c" front drive shaft yoke and shaft and wider chain? How much of the "j" do i actually use? im just needing to know which internal parts of the "j" i need to use.. I remember seeing a thread on building a 231c/j with lots of pics, but i can not find it.. could someone help?
1991 jeep wrangler.SOA. Chevy 305/ 700R4 tranny/ NP231C/J Transfer case, B&M Z gate shifter, Autometer gauges. Mickey Thompson Classic Lock 2s/ 33x12.5x15 federal couragia's. Bushwacker flares.
marvinb is offline
Another 4.0 Swap question...head swap vs. full engine swap Mol YJ Wrangler Technical Forum 11 10-18-2010 04:11 AM
Rubi swap / Axle swap (merged) tjmike TJ Wrangler Technical Forum 5 06-10-2010 01:04 PM
Gathering parts for Axle swap, SOA, and V8 swap... tank29 YJ Wrangler Technical Forum 7 12-03-2009 02:42 AM
HVAC Control Swap: Swap just the lower ac/heater housing, or all of it? Justin Brimm TJ Wrangler Technical Forum 5 12-20-2007 03:29 AM
