#1 | |
v8 motor mounts sbc
im putting in a 77 350sbc in my yj. problem im having is deciding between AA and Novak engine mounts. Welding in is no problem nor is cutting the old ones away etc. The concern is im using an np205 transfer case and it drops on the passenger side. i emailed novak to see how their mounts actually attach to the frame as i dont see how that would lol. any input from those who've used these? and do i have to nudge the engine a bit more to the drivers side for clearance or what's the deal? thanks
#2 |
Junior Member
I used the Advance Adapters - weld-in mounts. Just use 1/4" square tubing to make the spacers - mine was 1 1/2" but your may/will be different. Mine had to be offset to the passenger side, i.e. spacer on the driver side, to line up the tail piece with the rear diff. yoke. Advantage - let me set the motor a little lower in the frame and still maintain clearance.
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
