V8 into a YJ? - JeepForum.com
post #1 of 7 Old 10-11-2012, 07:40 PM Thread Starter
Jeepcanada
V8 into a YJ?
I've seen Jeep YJ's advertised on eBay with a V8 stuffed under the hood... Now I'm wondering if it is an easy swap and what major work needs to happen before the engine can go in. Let's assume that the Jeep doesn't have to pass any emissions tests afterwards...
Jeepcanada is offline
post #2 of 7 Old 10-11-2012, 08:00 PM
Noltz
YJ Wrangler
Stuffing a V8 under the hood is fairly simple if you have fabrication skills. The problem lies in making it work. The cooling system needs upgrading. The stock transmission must be adapted or replaced. The rear axle will not survive long. The fuel system must be adapted. The gauges have to be hooked into the new sensors, and the starter & alternator must be adapted into the vehicles wiring harness. And if it's Fuel Injected, you need to wire a complete engine harness.
It's certainly do-able, and if you keep it carburated it's much simpler. Personally I'd love to get a complete powertrain from a 5.3 Chev, with their 5 speed automatics. It's a LOT of wiring but do a bit at a time and keep it simple, and you've got 315hp/338tq and better fuel mileage. Swap an 8.8 in the rear to match your upgraded D30 front and it's good to go.
-Noltz
'91 Frankenheep YJ. 4.0, 4" BDS, Richmond 8.8, Titan 12k, 35" KM2's, rust.
'88 YJ, 4.2/4.0 head, +4" & shackles, BFG 33's (sold)
Noltz is offline
post #3 of 7 Old 10-11-2012, 10:46 PM
stevehoj
If you have a 4.0 / 4.2, an AMC V8 almost "bolts in" with ancillary support systems only to optimize. I went the 401 route (+ 0.060" - 413 cid).
Of course, there are upgrades to come depending on your intent and how aggressive with the accelerator.
08 Tundra CrewMax TRD 5.7, 07 Jeep GC-SRT8, 01 Lightning (sold), 96 Impala SS (sold), 93 RX-7 Twin Turbo (sold), 90 Wrangler 413 cid (AMC 401 +0.060), 71 Formula 400 (sold), 72 Formula 350 (sold), 71 Firebird 350 (sold), 69 Firebird 462 cid (455 +0.030)
stevehoj is offline
post #4 of 7 Old 10-11-2012, 10:59 PM
czjeeper
My opinion only, but I wouldn't bother w/any type of engine swap if it didn't include fuel injection.
US Army combat vet
2011 Grand Cherokee Laredo 3.6
Armed Forces Jeeps Member #125
Red Jeep Club Member #251
In the Portland/Vancouver area? Check 'em out!
czjeeper is offline
post #5 of 7 Old 10-12-2012, 12:36 AM
scubamc
Start reading here.
After you have finished with that, read some more here.
Then try here for more info.
5.3 Swap
And another
Depending on which motor you go with will determine the amount of work involved. They will all require motor mounts, adapters and welding. I am running a 2008 5.3 with the 4l60e trans. It took three months to finish the swap and another month to work out some bugs.
Horsepower is like a hot girl with STDs. You know you want to hit it but you're afraid of the consequences.
scubamc is offline
post #6 of 7 Old 10-12-2012, 11:31 AM
superj
i am starting a 302 swap but i am carb'd currently (87 yj) and putting in a carb'd 302 from a bronco so mine will be the easiest type of swap.
too bad i am such a procrastinator. i probably could have had this swap done at the beginning of summer but now summer's over and still not even started
I don't feel like working on anything at this time so i sold my yj.
superj is offline
post #7 of 7 Old 10-12-2012, 07:33 PM
lutzke21
I "was" in the process of dropping in my 5.7 TBI (currently torn down for rebuild) and 60e out of my '95 burb, but now I'm going to go with a lower mileage LQ4 or 9. More powerful AND better fuel economy, and ODB II to boot.
I gotta agree, need the fuel injection if you plan to do any off reading that includes ascents and decents. All told, TBI is probably the easiest fuel injection you can do. No high angle fuel starvation, no electronic issues.
After owning a Denali for a few years, I just want the 6L in there...
-Scott
'94 YJ on 35s
M C L M M
lutzke21 is offline
v8
