V8 conversion running to hot! - JeepForum.com
post #1 of 21 Old 04-06-2010, 01:12 AM Thread Starter
owens261
I have a V8 yj with a crate motor Chevy 350. I have trouble with it running hot just about 210. the A/C is not hooked up yet and when it is will definitely get hotter. I have a 4 coil aluminum radiator with an electric fan. I've changed the thermostat from none, to 180 now to 160. I have done everything I can think of to help it. Please help!!!!!
owens261 is offline
post #2 of 21 Old 04-06-2010, 04:54 AM
Mark05059
sounds like it may have air in the system somewhere... Take the cap off the radiator and let it circulate... Fill as needed while squeezing the upper hose... be sure to watch the fingers!!
1998 ZJ 5.2 Auto
1989 Wrangler Black Bone Stock 2.5l 5spd
/l , [____],
|---L--[]lllllll[]-
()_) ()_)==O=)_)
Mark05059 is offline
post #3 of 21 Old 04-06-2010, 05:32 AM
1998zj
What kind of fan setup do you have and how is the shroud?
"Our lady of blessed acceleration don't fail me now"
1998zj is offline
post #4 of 21 Old 04-06-2010, 05:37 AM
dodger889
Do not run with a thermostat. Now if you install a 160* thermostat that would be better. Without a thermostat your coolant is circulating too fast not cooling like it should. You will get what are called hot spots in the engine where there is no cooling at all.
A 89 yj with a 4.0 aw4 sye out of an 92xj. Now the hard part is done time to get it up in the air just a bit. Working on 8.8 with 3.73 and lsd for the rear. and new D30 hp with 3.73 .
For those who have not figured this out I'm old school but can handle the new too.
Originally Posted by bigsquat View Post
im just cheap, and cheap makes you creative.
dodger889 is offline
post #5 of 21 Old 04-06-2010, 07:01 AM
Louie4
What kind of gauge are your using to read the temperature? Are you sure your fan is wired correctly? Did you flush the heater core and rest of the system prior to the V8 conversion? Does it run hot at highway speeds or when sitting still or all the time?
Lou
YJOTM July 2012
YJOTM February 2014
Louie4 is offline
post #6 of 21 Old 04-06-2010, 10:20 AM Thread Starter
owens261
The fan is electric and is set to come on at 180 degrees and sits in it's own shroud. There is already a 160 thermostat in it. The temperature gauges are the Phantoms made by Auto Meter run through a sending unit (not electric). I can't say on the heater core being flushed prior to the conversion, bought it with the conversion done. The temperature was usually getting warmer while at highway speeds.......and maintains at around 200. I haven't taken it trail riding for a while but at one point it did it at a flat crawl but I think I've taken care of that.
owens261 is offline
post #7 of 21 Old 04-06-2010, 10:39 AM
MJMPC
Is the radiator new did you install it your self If not it may be stopped up see if you can get hold of a IR temp gun.
MIKE
MJM Powder Coating
Elizabethtown Ky.
MJMPC is offline
post #8 of 21 Old 04-06-2010, 10:57 AM
4.7stroker
There is no problem with running at 210f. With a 4 core rad an electric fan and a 180f stat you should be just fine.
My rig runs @210f all day long as do most vehicles.
Dwayne
[url]
Prevent Flat Tappet Cam Failure.
[url]
4.7stroker is offline
post #9 of 21 Old 04-06-2010, 11:53 AM Thread Starter
owens261
This engine was said that it's optimale running temp is 200f. Why doesn't the engine cool down so that the fan is not on constantly (basically not catching up)
owens261 is offline
post #10 of 21 Old 04-06-2010, 03:03 PM
5.7YJ
5.7YJ's Avatar
1987 YJ Wrangler
If it's getting hot driving down the road, it might have a restriction in flow. How does it do at idle and has this been a problem since you bought it?
5.7YJ is offline
post #11 of 21 Old 04-06-2010, 06:35 PM
greyarea
how many miles are on the new engine? In my experience with new engines they will run a little how on the break in due to higher friction of the internal components. Might want to put some miles on it and see what happens.
greyarea is offline
post #12 of 21 Old 04-06-2010, 07:33 PM
highrolrcustoms
i use to build drag cars before i got into 4x4s and we would have problems with them getting hot and did everything you mentioned and the best thing we found was a good electric water pump!!! that way it will spin at full speed circulating water reguardless of engine speed
95 yj juggy, backhalfed, 3 link front with 16" fox dual rate remote resi coilovers, 4 link rear with 16" fox air shocks, Monster Stak 2 Speed transfer case 4.33:1, full width ford 78/79 dana 60hp front axle with 538 gears and full spool, ford sterling 10.25 full width rear axle with 538 gears welded and disc brake conversion, 42x15 swamper tsl's on 15x8 Allied wheels 3.5" backspacing with DIY beadlocks, High Steer with 1.5x.250 dom tubing, Full Hydro steering, custom cage, rci 2161a fuel cell ,smitty xrc 8 winch, cv driveshaft, jk motor mount lift, racing seats with simpson 5 point harnesses
"THE MORE YA PLAY WITH IT.....THE BIGGER IT GETS"
highrolrcustoms is offline
post #13 of 21 Old 04-06-2010, 07:49 PM
1 ton yj
1 ton yj's Avatar
guys he's 210 that's not hot. my 350 used to run perfect at 210. Gen III engines run that hot from the factory.
1 ton yj is offline
post #14 of 21 Old 04-07-2010, 02:26 AM Thread Starter
owens261
If 210 is ok why won't the engine catch up to cool down. While I was at idle the fan kicked on at 180 cooled then shut down. The fan again kicked on again at 180 and never shut off again, it never was able to cool down and let the fan take a rest and stop. Basically it's not catching up temp wise.
owens261 is offline
post #15 of 21 Old 04-07-2010, 03:43 AM
dodger889
Ok do you know which 350 you have in there? Now what mods have been done? The 350 GM has been around since back in the late 60's to present. Fuel injection (tbi, mpi )or carbed you really need to say more than 350 there are a lot of other details needed to even start to give you more information on how to say if 210 is correct or not. Like what heads on what block. Now some of the new heads will bolt to an old block and not have the right coolant flow. The wrong head gaskets can cause the problem you are talking about. Compression ratios with the wrong fuel grade, tuning and so forth. What fan do you have in CFM's. You might not have enough air flow.
Oh what you are seeing about normal . Here is something to watch now if you take it for a drive then pull up to a stop and the temperature start to rise above the 210 and not cool back down fairly quickly to the 210 then you have a problem.Or slow running like in stop and go traffic and gets hot now you have a cooling problem.
ZJ Tie Rod Conversion Ghaniba TJ Wrangler Technical Forum 2 07-31-2009 06:28 AM
Running Lights running all the time. Wolf92XJ TJ Wrangler Technical Forum 3 08-25-2008 09:37 AM
Anyone running the NOVAK conversion kit? JeepRocks86 TJ Wrangler Technical Forum 20 05-30-2006 10:00 PM
H4 conversion captain_andrew TJ Wrangler Technical Forum 68 12-02-2004 02:43 PM
2.5L to 4.0L Conversion...HELP!! Yellow91YJ YJ Wrangler Technical Forum 3 04-30-2003 08:03 PM
