V-8 Conversion process started - Page 9 - JeepForum.com
post #121 of 157 Old 04-26-2012, 04:01 AM
mike_breaker_5
Originally Posted by mylilyj View Post
How is mine not a true magnum. I am sure my mopar perf pcm is getting at least 250hp out of it.
Anywho I run rubicon express xd 4inch lift springs. No bent springs yet. But i try and keep the wrap under control by not hammering from a stand still. Kick down gear with the auto impresses everyone that's been in the passenger seat though.
was i talking to you? nope.
mopar has an LA block and a magnum top end. hence not a true magnum.
Ratmonkey donation page. all proceeds will go to his family.
it's not much to look at... but it's mine.
5.2lswap, metalcloaks, bedliner, tucked belly, d60's, soon to be nv4500 and d300.
mike_breaker_5 is offline
post #122 of 157 Old 04-26-2012, 07:08 PM Thread Starter
MoparFreak69
Originally Posted by mike_breaker_5 View Post
mopar have you had alot of problems with torqued springs with the magnum in there? i know yours isn't a true magnum but still...
I was having bad spring wrap and wheel hop after I went SOA. When I was still running SUA with the skyjacker springs I didn't notice any problems with wrap or hop. After the SOA flip I ended up having to go with a traction bar. I kept blowing u-joints up. After the traction bar all is well again and I can burn rubber to my heart's content if I so choose to.
I imagine my almost Magnum produces right around the same power a stock magnum engine produces because I have all magnum specific parts except roller lifters.
For the poster who asked why I used the block I did to build my engine, the simple answer is I had it laying around, so I used it. No other reason for it. I am currently (very slowly I might add) building a Magnum block to swap in place of the LA block as it is getting very very VERY tired.
90 YJ 5.2 Magnum, AX-15, 231 SYE'd
D44 front, welded/trussed AMC20HD rear. 4.56 gears soonish.
Western 6 lug aluminum wheels, with 35x12.50x15 Wrangler MTRs
MoparFreak69 is offline
post #123 of 157 Old 04-27-2012, 04:33 AM
mylilyj
Lol. My bad.
on facebook
mylilyj is offline
post #124 of 157 Old 04-27-2012, 04:42 AM
Prekman
Guys, without hijacking the thread, in place of a 5.2, a 4.7 from a WJ would it be awfully more difficult (and expensive) to swap...i've read a couple of posts about OBD and transmission issues? The reason for the question is that apparently the 4.7 would have a better m.p.gallon perf..I am talking about the "mild" 4.7 not the overland version.
Prekman is offline
post #125 of 157 Old 04-27-2012, 06:35 AM
mike_breaker_5
what type of traction bar are you running? i came by a skyjacker one with everything except the "C" bracket that welds to the axle for almost nothing.
however before the d60's go in, hopefully this summer, i will be sua and i am still wrapping my drivers side spring. i guess i'll drive a jeep that leans to the right until the axle swap is done.
you may want to look into a reman 5.2, that's the route i will be going after i get all the other large mods completed. you can find a fresh 5.2 magnum long block minus the intake and TB for right around $1500 before freight. the 5.9 isn't but a few hundred more and it will bolt right in and plug into every wire on your rig as well, just sayin . i'm already running a 5.9l ecm i am leaning towards this aswell.
post #126 of 157 Old 04-27-2012, 06:43 AM
mike_breaker_5
i have read somewhere that the 4.7 and the older 5.2 use a "mostly compatible bell housing bold pattern. if memory serves, i think there are 2 holes that need modified to put a 3.9l bell housing on the 4.7. do some research, i'm sure someone has a writeup on it somewhere here. or, go to the junkyard and ask for a bell housing from both, trace each on a piece of cardboard, and compare the differences.
as far as the obd is concerned i think one main difference is the lack of the ability to bypass the egr on the newer engines. that is other than the obvious fact it's a different diagnostic language used by the ecm, however many obd2 sensors are usable on an obd1 system. just not the other way, as in most computer applications, you can go back but can usually not go forward with compatibility in programming.
post #127 of 157 Old 04-27-2012, 06:58 AM
Prekman
Thx Mike..Maybe better mileage is not worth the xtra money and the trickier installation..I think even in Novak pages they advise a chevy 360 then the 318 and do not talk at all for the 4.7...
Prekman is offline
post #128 of 157 Old 04-27-2012, 07:34 PM Thread Starter
MoparFreak69
The 4.7 honestly isn't a great motor. There isn't much aftermarket support because they really aren't stout enough to handle much more power than a stock build.
Mike, the main reasons I am building a motor myself are;
I have a good block that I got for free.
Other than sourcing a cam I will have about $90 into rebuilding it.
My current heads have already been gone through so I am just going to transfer all that stuff over to the new block.
I have many many other things I could do with that extra $1400 like roll cage, goodies for the crossfire, etc.
As far as my traction bar, I just built it myself out of 1/4 wall tube and heim joints. I think I posted up pics of it in my build thread in my signature. I think for the tabs and everything I spent like $100 on it.
post #129 of 157 Old 04-27-2012, 07:40 PM Thread Starter
MoparFreak69
Everybody recommends a Chevy 350 swap because they are a dime a dozen. I personally wouldn't put one in any of mys rig to try to sell it. They are a garbage motor, the whole SBC line. You run them for a while then throw them away.
The magnum block I am building had well over 240,000 miles on it. Had never been apart before I dove into it. The factory crosshatching in the cylinder is still intact all over the bore except a very small spot at the very top of the cylinder. A simple hone job brought it back into great shape and a set of standard sized rings slide right in with perfect ring end gaps. Cant ask for better than that can I?
post #130 of 157 Old 04-27-2012, 07:44 PM
czjeeper
I agree, the 4.7 is garbage.
I know that will piss off all the grand cherokee guys, but I wouldn't use one if you gave it to me.
US Army combat vet
2011 Grand Cherokee Laredo 3.6
Armed Forces Jeeps Member #125
Red Jeep Club Member #251
In the Portland/Vancouver area? Check 'em out!
czjeeper is offline
post #131 of 157 Old 04-28-2012, 02:42 AM
Prekman
...so long for a potential and more expensive 4.7.. I will go for the 318...
Do you think it could be swaped with its transmission (auto) and tranny...modified in order to offer 2WD or a modified 231 + AX15 is easier? I've heard that there were clearance issues when placing the whole package (motor-transm-transfer) in YJ hood, though it can be done
Prekman is offline
post #132 of 157 Old 04-28-2012, 04:31 AM
Rynfw100
That's why you test fit everything.
My 5.2L V8 swap and Jeep build:
http://www.jeepforum.com/forum/f12/1993-2-5l-jeep-wrangler-build-5-2l-swap-1210512
Rynfw100 is offline
post #133 of 157 Old 04-28-2012, 06:22 AM
mike_breaker_5
i read this 3 times and have no idea what you are trying to ask here.
post #134 of 157 Old 04-28-2012, 10:59 AM
stoveguy01
The 5.2 and 4spd auto fit in a yj like they were made to be there its really a shame chrysler never offered them in the yj there sales would have gone thru the roof. its not over powering the drive train (not counting the 35) gets better gas milage sounds alot better.
US ARMY COMBAT VET
MODIFY, ADAPT, & OVERCOME
stoveguy01 is offline
post #135 of 157 Old 04-28-2012, 04:38 PM Thread Starter
MoparFreak69
You can fit a 318 and its auto trans (A518 more than likely) along with a transfer case into a YJ. The auto it only about 2" longer than the AX-15 so it will work just fine as long as the engine is placed carefully in the frame to give as much clearance as possible. No need to downgrade to strictly 2wd to have an automatic.
5.2 , 5.2l
D44 Swap Process missionAvs TJ Wrangler Technical Forum 14 09-16-2009 02:54 PM
88 YJ Won't shift when started from neutral, works fine when started in gear NateWithoutBeer YJ Wrangler Technical Forum 2 06-20-2009 04:40 PM
New Process Gear cj847 Wrangler General Discussion 10 02-07-2009 08:11 AM
I don't know how many of you here would do this, but I am in the process and need som charlescho TJ Wrangler Technical Forum 28 05-30-2007 02:54 PM
modification process????? Jeepin_Al TJ Wrangler Technical Forum 4 06-16-2004 12:52 PM
