Using different Jeep parts - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > Using different Jeep parts
PANDEMIC-USA 50" Double row LED LIGHT BAR!! These thiANOTHER Rockridge4wd Creation!! Spare Tire Carrier Delete The Jeep Forum Discount is ON!
Unread 07-26-2015, 08:13 PM   #1
AnotherJeeper
Hey guys,
I was wondering if someone could let me know if i could use some parts from a 1992 Jeep wrangler (Automatic V6) onto a 1988 Jeep Wrangler (Manual V6) The Parts that I'm needing to replace is basically the entire piston chamber and the crankshaft.
AnotherJeeper is offline   Reply With Quote Quick reply to this message
Unread 07-27-2015, 12:41 AM   #2
Knuckelhead
AFSOC Retired
Knuckelhead's Avatar
Originally Posted by AnotherJeeper View Post
Hey guys,
Pre JK Wranglers came with a V6?...
Knuckelhead is offline   Reply With Quote Quick reply to this message
Unread 07-27-2015, 05:22 AM   #3
tyvanwie
Considering those are both YJs, pretty much everything should work. Might want to go over to YJ tech though.
tyvanwie is offline   Reply With Quote Quick reply to this message
Unread 07-27-2015, 09:10 AM   #4
Randonexplosion
Randonexplosion's Avatar
The '92 is a 4.0 Inline 6 and the '88 is a 4.2 Inline 6. Not much is interchangeable. Guys use 4.2 parts to stroke their 4.0 so I'm gonna say that you couldnt use the pistons or crank without a considerable amount of work.
5.3/4 link build
Looking for 92+ front female seatbelts
Randonexplosion is online now   Reply With Quote Quick reply to this message
Unread 07-27-2015, 12:46 PM   #5
roadyrob
1987 YJ Wrangler
the pistons wont work, they are different size. the 4.2 crankshaft into the 4.0 makes it into a stroker but requires some extra work . the 4.0 head onto a 4.2 is a popular mod. the flywheel will work, starter and water pump too.
Do everything with a positive attitude, it won't always work but you'll piss enough people off to make it worthwhile.
the voices aren't real but they sure have good ideas.
roadyrob is online now   Reply With Quote Quick reply to this message
Unread 07-27-2015, 04:19 PM   #6
timatoe
timatoe's Avatar
Like mentioned the engines are different. I'd just swap the entire 4.0 into the 88 if you're robbing parts off the 92 anyhow.
timatoe is offline   Reply With Quote Quick reply to this message
Unread 07-27-2015, 05:49 PM   #7
crackedcornish
you'd be ahead fixing up the '92
Orange Jeep Club #88
˙ɹǝʌo ɹǝʇndɯoɔ ɹnoʎ dılɟ sıɥʇ pɐǝɹ uɐɔ noʎ ɟı
crackedcornish is offline   Reply With Quote Quick reply to this message
