Urethane Body Mount Torque - JeepForum.com
post #1 of 4 Old 09-03-2013, 09:21 AM Thread Starter
tom_sprecher
The installation instructions say torque to factory specs (50 & 35#). I got to 25# and it was smashing the crap out of the bushings since there are no sleeves used. You can't use the factory sleeves since they are mushroom shaped.
Called Energy Suspension and the tech was no help ("if it says factory specs that's what you should use"). Should I just run a lower torque, make up some sleeves or what?
Thanks,
Tom
tom_sprecher is offline
post #2 of 4 Old 09-03-2013, 09:36 AM
jbolty
jbolty's Avatar
Every body lift I have ever seen uses either the factory sleeves with extension tubes or includes new longer sleeves. The whole point is to torque against the metal and not flatten the rubber. Same as the spring shackles
jbolty is offline
post #3 of 4 Old 09-03-2013, 11:45 AM Thread Starter
tom_sprecher
After looking more closely you can use the OEM sleeves. Too bad I threw half of them away do to rust thinking the new kit would include new sleeves. Just gives me something else to fabricate.
The big mounts along the sides can use 1/2" pipe (.840" x .120" wall) while the smaller ones in the back need 1" x .095 tubing.
Tom
post #4 of 4 Old 09-03-2013, 11:49 AM
Anticanman
RIP one good jeeper
Anticanman's Avatar
You always want metal bushings inside. However just torquing them to a point where the bottom washer starts to deform is where I stopped with mine.
Luck Favours The Prepared
Anticanman is offline
