01-05-2012, 11:17 AM
#1
Just recently slapped on 35" MTZ's on my 93 Jeep YJ along with the extra weight of my full metalcloak armor. Now my stopping power has gone down tremendously!
Been researching on brake upgrades for my rig and found a few things and wanted opinions...
Putting in a 95 double diaphram vacuum booster, along with the corresponding 95 master cylinder.
This seems to be the peoples choice in a "simple" and relatively easy brake upgrade.
http://www.links4jeeps.com/forum/index.php?topic=9425.0
While looking for other options i ran across some thread where this guy uses a ford E-350 master cylinder as his upgrade because it has a larger fluid reservoir. and it seems relatively simple to install as well.
http://www.jeepaholics.com/support/Topic657042.aspx
My question is should i just go with the 95 v/b and m/c
OR should i try to do a combo of the two with the 95 v/b and ford e-350 m/c?????
seems to me if the ford m/c is bigger than what the 95 has, and the v/b on the 95 is better than my stock 93. WHY couldnt i just combine the two for a mutant Frankenstein like setup that would work best?
just a thought
btw already have rear disc conversion as that was a nice little feature with the 8.8 install i did a few years back
Its hip to be square
Full Metalcloak. Poison Spyder Trailgate & Rear Bumper. Custom Front Bumper. 3.5" Black Diamond. 35" Mtz. KC lights. Delta Headlights. Corbeau. Supper 44 Flowmaster Diamond plate. Savvy Tail lights. Custom 3rd brake light. Superbrightleds.com
01-05-2012, 12:04 PM
#2
1995 Wrangler
if you are going to stick with the D30 here is an additional option to consider as well. From another thread.
Originally Posted by Bone Down
Back Road Jeepin
01-05-2012, 01:50 PM
#4
Originally Posted by glenn-91YJ
I'll be doing the same hopefully before spring, got the entire set up for $35.
OP, there's varied opinion on the larger reservoir idea from the E350 some say it's great, others say that due to the larger reservoir there's less pressure leading to more foot force at the pedal.
01-05-2012, 07:28 PM
#5
Thank you bone for those links. I have considered the wj knuckle swap but i think i am going to save that for when i upgrade my dana 30 all at once.
I also have looked into the tj swap but i would like this to be as easy for me as possible so i can bare the cold and go out and change it soon since it is snowing outside and my jeep is my DD.
dont really wanna slide all over the place this winter with sh*tty brakes haha
And i am going to read more about the E350 swap and figure out if i should attempt it
In the meantime i discovered this on ebay and was wondering what you guys think
http://www.ebay.com/itm/1974-1995-Je...item336e436cd0
its a little pricy but it seems to be nearly identical to the 95 swap and its all shiny and new and what not...
plus its the cheapest direct bolt on upgrade i have seen online
01-05-2012, 11:48 PM
#6
$30 for shipping seems a bit high, but otherwise that looks like a pretty decent deal.
01-06-2012, 12:07 AM
#7
check out a 'hydrobooster' uses power steering fluid instead of brake fluid. here is a link to where someone installed it on their Jeep. A company makes a kit specifically for Jeeps and is said to improve braking for larger tires.
http://www.stu-offroad.com/suspensio...droboost-1.htm
01-06-2012, 01:28 AM
#8
1995 Wrangler
No worries, it is like a multi upgrade in one shot, on the braking side you get larger twin piston WJ Calipers built for the heavier WJ's
Back Road Jeepin
01-06-2012, 01:34 AM
#9
No...
It uses powersteering fluid pressure instead of vaccum pressure. I personally have experiance with hydroboost breaks outside of my of my jeep and they are fantastic!
01-06-2012, 05:09 AM
#10
As for the double diaprham brake booster. I have been looking into that and it seems that only the 95 4.0 I6 has the double diaphram one. The 95 2.5 I4 doesnt have the double diaphram. If I am wrong I hope someone corrects me but through my searches so far thats what has turned up.
1995 YJ. 2 inch BDS Spring lift. 1 inch shackle lift. 33x12.5x15's. Engo 10,000 pound winch.
Originally Posted by Magnum
Big difference between a Warn winch and a worn wench. I'll take the former.
Originally Posted by Que89YJ
Oh and the phrase high cfm doesnt do that fan justice. It could suck peanut butter through a straw!
01-06-2012, 05:10 AM
#11
Originally Posted by 91BoD
No...
Power steering fluid and brake fluid are basically the same thing. They are both hydraulic fluid. The hydrboost replaces the vacuum booster not the brake fluid.
01-06-2012, 07:25 AM
#12
yeah siva i agree with your findings. through everything that i have been reading i think the double diaphram booster only comes on the I6 in 1995.
I would LOVE to do a hydroboost kit but that is way to much money for me, i have tons of other things i could do to my Jeep with that money. But its definitely a possibility for the future.
Today i am going to try and call some local junk yards and parts stores and possibly even stop at a dealership to see if i can locate a 95 double diaphram booster.
If i am completely unsuccessful in finding one i might just stick with the one i found on ebay
It may be a little more expensive than getting a used one, but it has a warranty, and deff cheaper than a hydroboost
01-06-2012, 08:01 AM
#13
I had no luck locating a used 95 setup at the local yards. None of the parts stores had any replacements either. That's why I ended up getting a TJ booster. The eBay unit looks nice but almost 3x what the TJ setup cost.
Owning a "Renegade" means being "Different"!
01-06-2012, 01:47 PM
#14
1995 Wrangler
Back Road Jeepin
Reason: added links
01-06-2012, 04:35 PM
#15
HI,
Kudos to you for being so responsible. Good brakes are a must and many modified Jeeps have horrible brakes. I don't care if they kill themselves but please, not other people. You know who you are.
I had the same problem and decided to go the hydroboost route. My brakes now work great with good sensitivity and stopping power. I have had zero problems in four years. I would say they are about as good as the original stock brakes, a huge improvement over where my brakes were before being modified.
Here is the site for the system I used:
http://www.vancopbs.com/category_s/66.htm
Give them a call. Vanco is very easy to work with.
Sparky
