Upgrading to 33"s Questions! - JeepForum.com
post #1 of 25 Old 06-22-2013, 07:55 PM Thread Starter
Razorback23
Im thinking about upgrading my YJ to run 33/12.50/R15 Goodyear Wranglers. Im getting a 2.5 rough country. Can I run the 33s on just the 2.5 for a little bit until I get a body lift or bigger shackles? Also should I do a body lift or shackles? And is there anything extra I need to get when getting these size tires? Brakes, Speedometer, Gears, etc? And do I REALLY need it? Thanks guys!
Razorback23 is offline
post #2 of 25 Old 06-22-2013, 08:13 PM
ferriolom
I think everyone's jeep is a little different and your backspacing comes into play a little bit also.
I was running 33 12.50's on mine with nothing more than BSERK's shackles, and there's no way they're more than 2.5" oversized. I had zero rub and zero issues, and I was running Road Venture M/T's with an aggressive tread.
Now I had ZERO flex at all, so I doubt it left me any off-road capability, but they didn't rub.
ferriolom is offline
post #3 of 25 Old 06-22-2013, 08:21 PM
Anticanman
RIP one good jeeper
Anticanman's Avatar
I wouldn't do it.
Anticanman is offline
post #4 of 25 Old 06-22-2013, 08:33 PM Thread Starter
Razorback23
I wouldn't do it.
Any particular reason?
post #5 of 25 Old 06-22-2013, 08:38 PM
jbolty
jbolty's Avatar
2 1/2 lift is not enough for 33s, if you plan on flexing it at all.
33s, 2 1/2 lift, 1" body lift, 5/8 shackles and TJ flares.
Same set up, stuffing the tires and bending the front fenders.
jbolty is offline
post #6 of 25 Old 06-22-2013, 08:38 PM
Red93yj
2011 JK Wrangler
The rough country lifts suck, trust me I had one and it rode rough. Also the lift tends to sag.
Red93yj is offline
post #7 of 25 Old 06-22-2013, 08:40 PM
Red93yj
2011 JK Wrangler
Also I ran 33s with 5.5" of lift, so don't do it with 2.5" of lift.
Red93yj is offline
post #8 of 25 Old 06-22-2013, 08:49 PM
Anticanman
RIP one good jeeper
Anticanman's Avatar
Pretty much everything they said. Rough ride. Bad articulation. Not enough clearance.
post #9 of 25 Old 06-22-2013, 09:02 PM Thread Starter
Razorback23
Anything that I could add to the 2.5 to run the 33s?
post #10 of 25 Old 06-22-2013, 09:06 PM
Anticanman
RIP one good jeeper
Anticanman's Avatar
The OME 36r 2.5" springs are closer to 3" and if you add a 1" body lift and some TJ flares it should work out with the proper bumpstops.
post #11 of 25 Old 06-22-2013, 09:13 PM Thread Starter
Razorback23
Could I get by with the RC 2.5 shocks?
post #12 of 25 Old 06-22-2013, 09:15 PM
Anticanman
RIP one good jeeper
Anticanman's Avatar
Why would you want to? The old man emu shocks are comparable to clouds.
post #13 of 25 Old 06-22-2013, 09:23 PM
RIPNBST
LOLLERSKATES. My buddy runs a rough country lift with a body lift and 33's. He doesn't rub but the ride will knock fillings out and I can't really comment on flex. I cannot recommend you buy the RC 2.5" lift based on his jeep, even if you we're going to add a BL. It would still ride like a washing machine on spin cycle with a bowling ball in it.
I've heard nothing but good things about OME components but they tend to be more expensive than RC.
RIPNBST is offline
post #14 of 25 Old 06-22-2013, 09:28 PM Thread Starter
Razorback23
Well I'm only 16 and have no money. The RC lift was a birthday gift from my parents so I can't complain. And there's a local guy wanting to trade my 31s for 33s.
post #15 of 25 Old 06-22-2013, 09:47 PM
Anticanman
RIP one good jeeper
Anticanman's Avatar
Oh. I see.
Perhaps you would like to try the body lift.
