-   -   Upgrading to 33"s Questions! (http://www.jeepforum.com/forum/f12/upgrading-33-s-questions-1540032/)
Razorback23 06-22-2013 07:55 PM
Im thinking about upgrading my YJ to run 33/12.50/R15 Goodyear Wranglers. Im getting a 2.5 rough country. Can I run the 33s on just the 2.5 for a little bit until I get a body lift or bigger shackles? Also should I do a body lift or shackles? And is there anything extra I need to get when getting these size tires? Brakes, Speedometer, Gears, etc? And do I REALLY need it? Thanks guys!
ferriolom 06-22-2013 08:13 PM
I think everyone's jeep is a little different and your backspacing comes into play a little bit also.
I was running 33 12.50's on mine with nothing more than BSERK's shackles, and there's no way they're more than 2.5" oversized. I had zero rub and zero issues, and I was running Road Venture M/T's with an aggressive tread.
Now I had ZERO flex at all, so I doubt it left me any off-road capability, but they didn't rub.
Anticanman 06-22-2013 08:21 PM
I wouldn't do it.
Razorback23 06-22-2013 08:33 PM
Originally Posted by Anticanman (Post 15595392)
I wouldn't do it.
Any particular reason?
jbolty 06-22-2013 08:38 PM
2 1/2 lift is not enough for 33s, if you plan on flexing it at all.
33s, 2 1/2 lift, 1" body lift, 5/8 shackles and TJ flares.
http://i3.photobucket.com/albums/y95...PIM0764_sm.jpg
Same set up, stuffing the tires and bending the front fenders.
http://i3.photobucket.com/albums/y95...8/DSC_2350.jpg
Red93yj 06-22-2013 08:38 PM
The rough country lifts suck, trust me I had one and it rode rough. Also the lift tends to sag.
Red93yj 06-22-2013 08:40 PM
Also I ran 33s with 5.5" of lift, so don't do it with 2.5" of lift.
Anticanman 06-22-2013 08:49 PM
Pretty much everything they said. Rough ride. Bad articulation. Not enough clearance.
Razorback23 06-22-2013 09:02 PM
Anything that I could add to the 2.5 to run the 33s?
Anticanman 06-22-2013 09:06 PM
The OME 36r 2.5" springs are closer to 3" and if you add a 1" body lift and some TJ flares it should work out with the proper bumpstops.
Razorback23 06-22-2013 09:13 PM
Could I get by with the RC 2.5 shocks?
Anticanman 06-22-2013 09:15 PM
Why would you want to? The old man emu shocks are comparable to clouds.
RIPNBST 06-22-2013 09:23 PM
LOLLERSKATES. My buddy runs a rough country lift with a body lift and 33's. He doesn't rub but the ride will knock fillings out and I can't really comment on flex. I cannot recommend you buy the RC 2.5" lift based on his jeep, even if you we're going to add a BL. It would still ride like a washing machine on spin cycle with a bowling ball in it.
I've heard nothing but good things about OME components but they tend to be more expensive than RC.
Razorback23 06-22-2013 09:28 PM
Well I'm only 16 and have no money. The RC lift was a birthday gift from my parents so I can't complain. And there's a local guy wanting to trade my 31s for 33s.
Anticanman 06-22-2013 09:47 PM
Oh. I see.
Perhaps you would like to try the body lift.
The time now is 04:10 PM.
