Quantcast Upgraded head, but changed Exhaust Manifold so how do I get an exhaust system now? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > Upgraded head, but changed Exhaust Manifold so how do I get an exhaust system now?
Old 02-18-2009, 08:08 PM   #1
jeepdude1987
1987 YJ Wrangler
Ok, so I swapped to the 4.0 head, but I had to change to a pre-'91 cherokee exhaust manifold. This required me to cut the exhaust pipe. I cut the pipe after it passed under the engine cause I was looking at upgrading my exhaust to a TJ style, but now I don't think the switch will work cause the '91plus 4.0 exhaust manifold won't work at all.
What would a cost effective solution be?
1987 Wrangler YJ RED 4.2 5-speed, NP231, BFG 31x10.5R15 AT/KO on 15x8 gambler wheels.
Caution!!! Under construction!!!!!! Caution!!!
Finishing a 4.0 Cyl.head swap, Just got an AX-15 NP231J combo to replace the busted t-case and craptacular BA10/5. Adding Nutter bypass. Probably more to come before it is back as a DD!
jeepdude1987 is offline   Reply With Quote
Old 02-18-2009, 09:17 PM   #2
yjmudder90
I would go to a muffler shop and see what they can do for you. Might be an easy solution if you can get a tow.
1990 yj, 4.2, ax-15, 2.5" RC lift, 1/2" boom shackles, Herculiner inside, duplicolor outside, 33x12.50-15 Interco trxus mt's, Hacked body,
"The right of the people to keep and bear Arms shall not be infringed."
yjmudder90 is offline   Reply With Quote
Old 02-19-2009, 12:54 AM   #3
jeepdude1987
1987 YJ Wrangler
I was thinking that was a last resort. I really don't know how much that would cost, but if it came down to that or doing if myself I was at least going to call and as about an estimate.
Glock Forum
