Upgraded Brake Master Cylinder for my huge calipers on the HEEP. Dual Pistons & GM's
| TJ 5.25" Speaker Adapters - NalinMFG | Truck-Lite's New LED Headlamp Series | 4.25" 97-06 Jeep TJ Wrangler Lift Kit - NO SYE Needed |
#1 | |
BUILT. NOT BOUGHT.
yesterday i spent 20 minutes swapping out Master Cylinders in an effort to get better braking....
i used a 1978 grand marquis MC and adjusted the brake rod thingy IN about 6 turns. After bleeding my brakes this is what i've got... http://www.youtube.com/watch?v=U8GMNGyvyEw ignore the wiring mess. i'm still not done with my 4.0 / aw4 swap so i haven't clened the wiring up yet. ![]() ![]() ![]() ![]() ![]() ![]() ![]() the pedal is very hard.... feels almost like having manual brakes to be honest.... guess it's b/c the marquis came with hydroboost if i remember right..... maybe i'll throw on a vacuum pump...... ah... stock proportioning valve is being used... it is NOT modified.... and i still get slightly more bias to the rear on pavement as you can see..... an adjustable prop. valve will be added to the rear brake hydraulics and mounted to the dash somewhere...
'89 Wrangler, 4.0/AW4, 106" Wheelbase, SOA, custom XJ packs, 2" Body. Front High Pinion Dana 44 w/yukon super-joints, chromo inners and outers, and a Lincoln Locker. Rear Dana 60 w/Yukon 1.5" 35 Spline chomo shafts and detroit locker. 5.38 Yukon Gears. Hydro-Assist, 39.5x18" Boggers on 15x12 RockKrawler's w/ 2.75" of backspacing. Comp cut, tube fenders, custom bumpers and rock sliders, fuel cell, CB, Stewart Warner Gauges, SmittyBilt XRC8 Winch, 140 Amp CS-144 Alternator, Electric Fan, and a cooler of beer. 3897 lbs March 1st, 8pm. WILMINGTON, NC MEET & GREET @ HOOTERS! |
#2 |
BUILT. NOT BOUGHT.
oh, the holes in this MC were different sizes, just like the oem brake MC, but they were reversed so i just bent the brake lines, as shown , to hook it all up.
maybe i should have just put new fittings on each line instead of reversing them... not sure.... trial and error baby.... love it!
#3 |
If you want to experiment, get a Lincoln MC (84-90 Lincoln Mark 7 / 1 1/8" bore ) . They were not H-boosted and fit the bill.
Love the video
www.gaugeplates.com Switch panels for our jeeps 2008 Toyota Tundra RCSB 2002 SV650 Track bike 1995 wrangler 2.5L 1985 Mustang GT R-Blocked 357, PT74GTS turbo, Lentech, ect... |
#4 |
BUILT. NOT BOUGHT.
they weren't for 4 wheel discs though.
i actually had one of those in my hand when i got this one and decided to stick with what i got because of the larger rear fluid resevoir. a proportioning valve is next on my list....
#5 |
XJ on 37's
erik,
still running the stock prop valve, and have more brakes on the rear = you screwed up when you "just bent the lines" mate... you should have got adapter fittings, and kept the brakes as they should have been.... i tried the grand marquis, e350 a corvette m/c's, and god knows what else, before i bit the bullet and went ahead and got the dual diaphram booster. thats the only thing that gave me, IMO, excellent brakes. swap the lines back around to where they are supposed to be, and then see how the brakes are... martin
1998 XJ on 37's.JK Rubi axles with chromo shafts and ctm's, 4:1 transfer case, etc etc etc.The Cherylkee.... 1998 Range Rover 4.6 HSE 2000 4.7 4WD WJ with a rebuilt motor. 4.3/700r4/new frame buildup (YJ).... http://www.jeepforum.com/forum/f12/swap-offically-underway-324622/ Years to gain the hands on experience, and offer it freely. Minutes to gain the knowledge from the internet, and quote it just as freely. Choose wisely! |
#6 |
martin,
do you have a link to that booster? I was looking at a E-350 booster but might as well do it right the first time. Thanks -Michael
1994 YJ 4.0L 5 spd. flowmaster,15x12 wheels & 35x15 TSLs, sway bar discos, 3.5" leaves SOA + shackles, 2" body lift, JB steering bracket, SYE, M.O.R.E. anti-wrap bar, Bilsteins 5125s up front & BDS Hydros out back, axles in the works http://i178.photobucket.com/albums/w257/mwchitty/Image075.jpg |
#7 |
BUILT. NOT BOUGHT.
yea i guess i'll cut off the fittings and reflare te lines with the fittings the opposite way tomorrow and see..... they work great... just taking a little getting used to but so far so good....
#8 | |
XJ on 37's
will be a dual diaphram booster and a plastic m/c... if ye cant find them, shoot me a pm and i'll dig them out for you. or search,. i have posted up about them @5 times already... erik, the m/c is supposed to be the same way it was, if that makes sence? basically you made the rear reseviour feed the front brakes, and vice versa... when i was figuring out my brakes, a good flaring tool was worth its weight in gold... martin
1998 XJ on 37's.JK Rubi axles with chromo shafts and ctm's, 4:1 transfer case, etc etc etc.The Cherylkee.... 1998 Range Rover 4.6 HSE 2000 4.7 4WD WJ with a rebuilt motor. 4.3/700r4/new frame buildup (YJ).... http://www.jeepforum.com/forum/showthread.php?t=324622 Years to gain the hands on experience, and offer it freely. Minutes to gain the knowledge from the internet, and quote it just as freely. Choose wisely! |
#9 | |
#10 | |
P.S. sorry for the hi-jack Big-n-Broke. |
#11 | |
XJ on 37's
martin
#12 |
BUILT. NOT BOUGHT.
no worries on the hi-jack, we're all here to help eachother
![]() tomorrow night i'm going to put the lines back the other way... i was thinking about doing it tonight but i ran out of steam after redoing my gauges (ditched the crappy autometers and went with an almost-as-crappy set of steward warner's) -Erik <--- will be flaring away tomorrow right before i stretch the front 5"!
#13 |
Grand Poobah
sorry, another hi-jack. is the 95 brake booster different from a 94? I'm getting ready to do the 8.8 with disks and 33" tires. My next upgrade was going to be brakes and I was wondering if there is another way to get better brakes without having to buy a after market kit.
. "Is America ready for a real leader not just a reader?." _ Herman Cain http://www.oddhammer.com/tutorials/debt_clock/US_debt_clock.swf Live in Georgia? click here--> http://georgiacrawlers.com/ |
#14 | |
______ /l,[____], l---L -[]lllllll[] ()_) ()_)---)_) 98 TJ stock for now WWW.FLATLANDROCKCRAWLERS.COM 350 in my YJ..... http://www.jeepforum.com/forum/f12/my-350-swap-518364/ build thread: http://www.jeepforum.com/forum/f22/yj-dana-60-70-build-1122902/ |
#15 | |
XJ on 37's
1995 4.0 yj. 1995 means 1995, not 94,93 etc etc etc.....the last year they made yj's (1995) they finally figured the brakes needed a boost, so to say... so they got the dual diaphram booster and different m/c... class over. martin
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
