upgraded axle shafts - what year/month? 1995? - JeepForum.com
post #1 of 6 Old 01-12-2005, 08:58 PM Thread Starter
Mark_ZZ3
Mark_ZZ3's Avatar
I understand that Jeep upgraded the front axle shafts sometime in 1995. Is there any tell-tale signs to look for? I am trying to find a front diff from a 1995 4 cylinder Jeep ... 4.10 gears and the upgraded axles shafts.
Thanks
Mark.
PS. All 4 cylinders came with 4.10's right?
Mark_ZZ3 is offline
post #2 of 6 Old 01-12-2005, 09:28 PM
ErikJordan
Pimp Hand
ErikJordan's Avatar
all 95+ yj's have them.
___________________________________________
What is all of this talk of Savvily designed products?
ErikJordan is offline
post #3 of 6 Old 01-12-2005, 09:53 PM
lordmatt
lordmatt's Avatar
4cyl w/standard tranny was 4.10's, I thought. Auto got 3.73's... I think.
'91 YJ - Flat Black
35x12.50x15 BFG Mud-Terrain TA's on 15x8 Black Rockcrawlers
SOA, SYE
Cut fenders
Recessed tails
Herc's interior
Fabbed front bumper
misc fun stuff
lordmatt is offline
post #4 of 6 Old 01-12-2005, 10:06 PM
ErikJordan
Pimp Hand
ErikJordan's Avatar
i was referring to the 297x/760 u joint.
post #5 of 6 Old 01-12-2005, 10:18 PM
GrimJeeper91
GrimJeeper91's Avatar
It's my understanding that '94's with ABS also had the upgraded shafts. The '94 ABS shafts I stuffed in my '91 had ujoints that were larger than my stock '91 ujoints.
'91 YJ 4.O, Auto, Rr. D60 w/ 35 Spline Alloy USA Axles & Detriot Locker, Fr. D30 True-Trac, 4.56's, 4.5" Deaver Springs, Bilstein 5100's, 1" BL, Rubi Flares, 35x12.50 MT/R's on MT classic II's, Detroit Locker, Vanco Big Brakes, Booster & Master, Warn 9000XDI, York OBA, AA SYE & TW's DS's, Teraflex Belly Up, Rocker Guards...
GrimJeeper91 is offline
post #6 of 6 Old 01-13-2005, 04:30 AM
JeeperDon
Think Outside the Catalog
JeeperDon's Avatar
Yes, easy, the diameter of the cup on the bigger u-joint is about 1-1/8" in diameter. On the older shafts, the cup is about 1" only. The outside of the cup is easy to see on any parked jeep.
'93 YJ, '02 GM 4.3V6, SOA, dual ARB's, 8.8+D30(WarnHubs), 4.88s, 35" BFG KM2s, AX15, NP231+4:1+SYE+2LO, York OBA, Warn M8000.
Web Admin for
JeeperDon is online now
December TJ of The Month Contest and TJ of The YEAR info. SUBMIT NOW!! spyder6 TJ Wrangler Technical Forum 93 12-08-2009 05:13 PM
1971 thru 1995 4.2l which year was better ChicagoYJ YJ Wrangler Technical Forum 3 06-01-2009 06:49 PM
D35 axle: how different are driver and passenger axle shafts? ritjobbie YJ Wrangler Technical Forum 3 01-16-2009 06:47 PM
Do the rear axle shafts easily pull out like the front shafts? jclark50 TJ Wrangler Technical Forum 2 04-13-2008 10:10 PM
No more stuff this year (month... maybe) JPJeep TJ Wrangler Technical Forum 5 06-10-2002 10:11 AM
