Upgrade injectors,Fuel pressure regulator and Throttle body on 2.5 - JeepForum.com
post #1 of 7 Old 03-09-2010, 01:17 PM Thread Starter
Ironworker709
Ironworker709's Avatar
Upgrade injectors,Fuel pressure regulator and Throttle body 2.5, 4.0
I started searching info on better injectors for my 2.5 a few weeks ago because of the longer than usual starts and rough idle at times.
I came across this thread in the Cherokee forum,this applies to all 2.5's and 4.0's in the Jeep so i thought i would share the info and post the link in here for reference for anyone wanting to do so.
http://www.jeepforum.com/forum/f11/u...ml#post9049469
I put better used injectors ,a higher fuel pressure regulator and a 4.0 throttle body on mine and it made a GREAT difference in my case after reading what this guy on our forum named coas had to say about fuel injection systems,this guy makes ALOT of sense going into detail ,so i just posted the link in here instead of starting another LONG thread about it..
Don't DREAM your life, LIVE your dreams
Never forget 9/11
"Welding is like a woman,Get 'er HOT and Penetrate"
Gotta LOVE a person who knows everything about NOTHING
The only Thing necessary for the Evil to win is a good man to do nothing....
"How far you go in life depends on your being tender with the young,compassionate with the aged,sympathetic with the striving,and tolerant with the weak and strong--because someday YOU will have been all of these"....George Washington Carver
Want to know what an Ironworker is and the job scope of a Journeyman?..click here...
Ironworker709 is offline
post #2 of 7 Old 03-13-2010, 01:11 PM Thread Starter
Ironworker709
bump..................................
Never forget 9/11
post #3 of 7 Old 03-13-2010, 01:53 PM
Dewster196
did you swap the sensors from your 2.5 tb to the 4.0l tb or just left the 4.0l sensors also what was the part number of the fuel pressure regulator you used.
Dewster196 is offline
post #4 of 7 Old 05-10-2013, 06:55 PM
matrix311
Will these injectors work in my 2.5L engine? Are our injectors EV1 or EV6 connections?
http://www.ebay.com/itm/86-87-93-FOR...766c8a&vxp=mtr
Thanks!
Eric - *'92 White YJ, 4.5" custom Deaver springs, 35" MTRs, Tera-Low 4:1, CAI, Rear 8.8, Chromo D30, 4.88s, locked front/rear, full cage and front/rear tube fenders.
*'08 Silver Rubicon JKU 2.5" lift, 5.13's and 35's
matrix311 is offline
post #5 of 7 Old 05-10-2013, 10:25 PM
mrdeath2000
You want ev1.
93' YJ 2.5L, 4.88's, 8.8, E-Locker & LSD
mrdeath2000 is offline
post #6 of 7 Old 04-01-2014, 09:04 PM
Jeep-1995
is there any difference between the ford injectors for a 2.5 or a 4.0?
90 YJ 4 cyl 5 speed on 35"s
5" lift
99 TJ 6 cyl 5 speed on 32"s
bone stock
Jeep-1995 is offline
post #7 of 7 Old 04-02-2014, 07:19 AM
Que89YJ
Que89YJ is offline
fuel pressure regulator 2.5l Bryan01702 YJ Wrangler Technical Forum 8 01-26-2010 10:08 PM
4.0 throttle body with yellow top injectors mudking_ky87 TJ Wrangler Technical Forum 9 04-12-2009 12:07 PM
Fuel regulator or injectors going? czjeeper YJ Wrangler Technical Forum 4 03-14-2009 09:52 PM
How to clean injectors and throttle body? manalex YJ Wrangler Technical Forum 11 10-15-2007 02:31 PM
fuel pressure regulator Sfrid073 TJ Wrangler Technical Forum 2 07-22-2005 09:50 PM
