Unknown sensor - JeepForum.com
post #1 of 21 Old 01-20-2012, 01:35 PM Thread Starter
DirtRider1357
Unknown sensor
Can somebody tell me what this plug/sensor is as mine is broken and i would like to replace it. its located next the valve cover on driver side towards the back. in the first pic, the broken sensor is directly in the middle of the screen. coming from the center of the broken sensor is a single metal prong. if someone could give me an idea of what this is that would be awesome, thanks.
http://i1182.photobucket.com/albums/...0120121455.jpg
http://i1182.photobucket.com/albums/...0120121454.jpg
DirtRider1357 is offline
post #2 of 21 Old 01-20-2012, 01:40 PM
youngjeepr
I cant quite tell but it looks like your coolant temp sending unit
88 YJ- 4.7l stroker, AW4, SOA, 8.8, hp D30 powertrax no slip,3" front stretch with waggy springs, stock replacement springs in the rear, 35/12.5 r15 goodyear kevlars
youngjeepr is offline
post #3 of 21 Old 01-20-2012, 01:44 PM
muddy93
1987 FSJ Wagoneer
yep, kind of looks like temp sending unit. Does your temperature gauge work?
maroon 1987 Grand Wagoneer. stock for now...
muddy93 is offline
post #4 of 21 Old 01-20-2012, 01:47 PM
jbolty
jbolty's Avatar
First pic is definately the temp sender for he gauge.
jbolty is offline
post #5 of 21 Old 01-20-2012, 01:50 PM
Louie4
That is correct. They are about $11 from Autozone which is where I got mine. It works fine but I've heard others say they have problems with them and end up getting them from the dealership.
Link to the part on A-zone's website.
http://www.autozone.com/autozone/par...mString=search
Lou
YJOTM July 2012
YJOTM February 2014
Louie4 is offline
post #6 of 21 Old 01-20-2012, 02:23 PM
TA-YJ
Im going to say skip the headache and just get one from the dealer. Theyre not much more expensive there. I went through 3 generic ones before I finally got a dealer one that worked.
1992 YJ 2.5L
Engine Mods:4.0L TB, Ford Design III 19lb Injectors, Firepower Ignition System, Ford TBird Electric Fan, Pacesetter Header, Magnaflow Cat, Dynomax Super Turbo Exhaust
Suspension Mods:BDS 2" Lift, M.O.R.E. 5/8" HD Shackles, 1" Brown Dog MML
Other:LED Tails and Herculined
TA-YJ is offline
post #7 of 21 Old 01-20-2012, 04:50 PM Thread Starter
DirtRider1357
so wait, are there 2 coolant temp sensors?
post #8 of 21 Old 01-20-2012, 05:06 PM
youngjeepr
yes there is one that goes to your gauge the one in the picture and there is another one that goes to the ecm to tell it how much fuel to deliver
post #9 of 21 Old 01-20-2012, 05:07 PM
youngjeepr
never mind you have a carb. I think you only have one but im not to familiar with the 4.2
post #10 of 21 Old 01-20-2012, 05:12 PM Thread Starter
DirtRider1357
i have a 4.0 in mine
post #11 of 21 Old 01-20-2012, 05:14 PM
youngjeepr
then you most likely have the second one to go to the ECM
post #12 of 21 Old 01-20-2012, 05:24 PM Thread Starter
DirtRider1357
yea i had a sensor at the front of the motor and that one at the rear, i installed a set of sunpro mechanical gauges cause none of mine worked after the motor swap. i unscrewed the front cts and screwed in the sunpro temp sensor.
post #13 of 21 Old 01-20-2012, 05:25 PM
youngjeepr
so does your gauge work or no? how does the engine run?
post #14 of 21 Old 01-20-2012, 05:30 PM Thread Starter
DirtRider1357
the stock gauge doesnt work but the sunpro one does. the motor runs rough, idles a lil high. feels like it has a loss of power when accelerating, and smells like fuel when i shut it off
post #15 of 21 Old 01-20-2012, 05:48 PM
youngjeepr
what type of connector does the sunpro have on it? Sounds to me like you need to put the sunpro sensor in place of the one in the picture and the original in the place of the sunpro
Unknown lift PUMPJUNKY YJ Wrangler Technical Forum 6 11-16-2010 10:27 AM
Unknown to me belt # Kanook YJ Wrangler Technical Forum 4 01-26-2010 10:04 AM
Unknown Plugs minimudder YJ Wrangler Technical Forum 0 04-25-2008 02:45 PM
unknown plug madmikey TJ Wrangler Technical Forum 2 02-04-2006 08:11 AM
unknown connecter Meister_jeep YJ Wrangler Technical Forum 8 10-03-2002 06:20 PM
