Universal Joint Failure - JeepForum.com
post #1 of 11 Old 08-13-2011, 08:50 AM Thread Starter
JWELK
I have a '95 Wrangler 4.0, 5 spd.
It has 16 inch, the tires are P255 65R16.
The speedometer is accurate so the gearing has been changed.
At any rate we have gone through 3 universals in 4 yrs.
It gets driven about 9,000 miles /yr. Very little 4WD, no off road to speak of.
After all of this, what should I be looking for?
Thanks for all of the help on my previous request. Am looking into it as we speak. Had a lightning hit on the pole outside the house. One computer, printer, cordless phone DSL only took 3 wks to get it up and running..
Thanks,
Jim W
JWELK is offline
post #2 of 11 Old 08-13-2011, 09:01 AM
bigbossd1030
What do you mean it has 16 inch?
Not sure, but I would consider the pinion angles (or the angle of the Driveshaft in question).
Also it could be an unbalanced driveshaft.
I would maybe take it in to a shop that makes/specializes in DS and have them take a look at it.
/l ,[____],
l----L-[]lllllll[]-
()_)-()_)--o)_)
OFFICIAL JEEPER
Any Jeepers in Edmonton, AB
I am on channel 33.
I live, I ride, I am JEEP.
bigbossd1030 is offline
post #3 of 11 Old 08-13-2011, 09:07 AM
danlee
1987 YJ Wrangler
22 deg angle is real good for pinion angle, 30 degrees not so good
danlee is offline
post #4 of 11 Old 08-13-2011, 09:12 AM
MJMPC
Can you take some pics of your driveshaft angle ?
MIKE
MJM Powder Coating
Elizabethtown Ky.
MJMPC is offline
post #5 of 11 Old 08-13-2011, 12:09 PM Thread Starter
JWELK
16 Inch Rims
I'll get pix and take some measurements as soon as I get it back.
I asked the mechanic, he said they go bad frequently. I have a '95 Sahara with about the same mileage 70K or so, it has an auto, but I've never had a problem with its drivetrain.
Thanks,
Jim W
JWELK is offline
post #6 of 11 Old 08-13-2011, 01:11 PM
bigbossd1030
Originally Posted by JWELK View Post
16 Inch Rims
Thanks,
Jim W
Yeah same here, I have a 95 manual though, and I bought it off a friend I knew growing up and we did all the work on it together and we have never changed a ujoint yet. So no, that mechanic is an idiot and you should be going to someone else.
/l ,[____],
l----L-[]lllllll[]-
()_)-()_)--o)_)
OFFICIAL JEEPER
I am on channel 33.
post #7 of 11 Old 08-13-2011, 03:38 PM
19OlllllllO41
19OlllllllO41's Avatar
16 Inch Rims
Thanks,
Jim W
After you get us drive line angle pics, start searching for a new mechanic....
The Present:
'05 TJ Rubicon (Electric Lime Green)
'04 WJ
'46 CJ2A
The Past:
'83 CJ7, '92 YJ, '00 XJ, '99 TJ, '05 TJ Rubicon (Impact Orange)
19OlllllllO41 is offline
post #8 of 11 Old 08-13-2011, 11:04 PM
bandhmo2
The 95's used a larger ujoint on the axle end of the rear drive shaft then the front. There is something not right with the pinion yoke used so they eat ujoints. I was going through about 1 a year. This is a common and known issue.
bandhmo2 is offline
post #9 of 11 Old 08-13-2011, 11:29 PM
Xpress
Buy OEM u-joints?
All about that unibody life.
Xpress is offline
post #10 of 11 Old 08-14-2011, 08:31 AM
jbeebe
they don't go bad frequently. get a new mechanic. what brand u-joints are you putting in it? and like others have said, take pics of the driveshaft angle
jbeebe is offline
post #11 of 11 Old 08-14-2011, 11:08 AM
hesserdude07
u joint is like $10, i would be glad if thats all i had to replace on my jeep in a year...
1993 Silver YJ. SBC 300hp. 700r4. NP231 hybrid. 35" Mud Terrains. 7" Toyota Basterd packs. 8.8 Welded. D30 loc-rite. 1" body lift. 4" LED tails. Custom bumpers. Warn M8000. Hella's. (Trail rig)
hesserdude07 is offline
Universal Joint ? ShadowWolf YJ Wrangler Technical Forum 9 12-07-2010 07:53 PM
universal joint newyj YJ Wrangler Technical Forum 9 12-03-2010 01:41 PM
Help with 95 YJ Universal Joint claygarland YJ Wrangler Technical Forum 12 02-20-2010 06:12 AM
universal Universal Joint question likely universally asked.... firefighter315 YJ Wrangler Technical Forum 14 01-23-2009 01:04 PM
Universal Joint Q's for the D30 CanukYJ YJ Wrangler Technical Forum 6 06-11-2004 10:37 PM
