Universal Joint ? - JeepForum.com
post #1 of 10 Old 12-05-2010, 09:54 PM Thread Starter
ShadowWolf
Universal Joint ?
I need to change my Rear Universal Joint. I am currently without a bench Vise. I see a couple for sale on CL , but they are only 4.5'' seems kind of small to me, so the question is , would that be a big enough vise to fit the DS in with a couple of sockets ?
-==ShadowWolf==-
ShadowWolf is offline
post #2 of 10 Old 12-05-2010, 09:57 PM
Ferenckzy
You don't need a vice to change a U-Joint. Just rent the press kit from Advance Auto or Autozone. Or buy the one at Harbor Freight.
Just give us some quarters so we can get drunk.
'94 WhyJ, Tall, Locked, RCV'd
Ferenckzy is offline
post #3 of 10 Old 12-05-2010, 09:59 PM
Joe Dillard
Electric Chair Operator
Joe Dillard's Avatar
Have you considered a ujoint tool?
Something like this: 3-in-1 Ball Joint/U-Joint/C-Frame Press Service Kit
I carry one in my trail box & it has come in handy many times.
Joe Dillard is online now
post #4 of 10 Old 12-05-2010, 09:59 PM
justanotherjpr
You can do it with a ball peen hammer and a socket that fits inside the drive shaft's yoke. A 4.5" vice is big enough if you set the bearing caps in the jaws and whack the yoke, instead of trying to use the jaws to compress the caps in and out.
So do you actually hear your thoughts in your head or is it just sort of a dull roar before you smash your face into your keyboard and just submit whatever dumb **** ended up on the page?
justanotherjpr is offline
post #5 of 10 Old 12-05-2010, 10:10 PM
dagoober
you dont even need a vice or a press. i have had to change out 3 of them in a week once and all were either on the trail or the road. its really easy and only takes about 10 minutes. all you need is a hammer (i used a crescent wrench as a substitute since i dident have a hammer with me), a socket, and pliers. to remove the driveshaft you unbolt the straps holding it to the rear axle and then just pull the driveshaft out from the transfer case. you then need to take the c-clips out then you place the socket over the end of the u-joint and pound the cap out the other side. once you can get your pliers around the cap of the u-joint that is exposed just pull it out with the pliers. do the same for the one on the other side.
putting the new one in is pretty much just doing the opposite of taking it out. just remember to put some grease in the caps before you put it all back together.
don't bother spending money on a press or renting any tools if you don't need to. all you need is a hammer, a socket, and pliers.
________
l l , [____],
|---L--[]lllllll[]-
()_) ()_)==O=)_)
dagoober is offline
post #6 of 10 Old 12-05-2010, 11:10 PM Thread Starter
ShadowWolf
I'll try with the hammer first, And will also look into that tool if the hammer does not get it done. The vise on CL is only $20 might buy it anyway if it looks good, thanks guys.
-==ShadowWolf==-
post #7 of 10 Old 12-06-2010, 04:48 PM Thread Starter
ShadowWolf
I got under the jeep this morning to do the U-Joint, and noticed that the Yoke is pretty beat up , it looks like the PO drilled out one of the holes where the straps mount and just put a nut and bolt there the remaining strap bolts look a mess also. I ordered a Ubolt Yoke conversion kit from Quadratek when it comes in I will do the Universal joint and the yoke kit together probably this coming week end.
-==ShadowWolf==-
post #8 of 10 Old 12-06-2010, 05:12 PM
jay-h
Sometimes yes, sometimes no. I have changed U-joints in a truck stop parking lot (not a Jeep) but there have been times I needed to get them pressed out. No way to tell ahead of time.
I did buy the Harbor Freight unit, and it did the job for me.
jay-h is offline
post #9 of 10 Old 12-06-2010, 06:52 PM
MLJeeper
MLJeeper's Avatar
Ive completely worn out one of the harbour freight presses. Its crazy not to have one really if you jeep much. Ive replaced dozens of ujoints on the trail with it, a couple ball joints too and it made the job simple clean and quick. Well worth what little the HF press costs. Combined with a battery powered impact, on the trail its almost cheating its so easy.
Your limited slip differential sucks.
Any video of the sound?
MLJeeper is offline
post #10 of 10 Old 12-07-2010, 07:53 PM
newyj
I used a hammer and socket to do mine three days ago no sweat
wave back dammit, don't leave me hangin!
yes, I wave at night too
newyj is offline
universal joint newyj YJ Wrangler Technical Forum 9 12-03-2010 01:41 PM
Universal Joint DivineKaos TJ Wrangler Technical Forum 2 09-27-2010 09:51 AM
Help with 95 YJ Universal Joint claygarland YJ Wrangler Technical Forum 12 02-20-2010 06:12 AM
universal Universal Joint question likely universally asked.... firefighter315 YJ Wrangler Technical Forum 14 01-23-2009 01:04 PM
Universal Joint Q's for the D30 CanukYJ YJ Wrangler Technical Forum 6 06-11-2004 10:37 PM
