uneven brake pad wear ?? - JeepForum.com
post #1 of 8 Old 01-17-2006, 09:53 AM Thread Starter
jeepinjc
jeepinjc's Avatar
Ok well I used the search button and nothing so ask the masters. I replaced the calipers on the front of my jeep, new pads,rotors. Well I took my tire off the other day and noticed that the outside pad had wore alot and the inside pad wore very little, so whats up and how do I fix it
Blue 93' YJ, 4.0, 5spd, skyjacker 4" lift, crager simulated beadlocks w/33" bfg muds, skyjacker swaybar disco's, dana 30/35 w/ 4:10's, skyjacker t-case drop, and many mods to do yet
Jeep Drivers who dig COUNTRY music member #13
jeepinjc is offline
post #2 of 8 Old 01-17-2006, 10:50 PM
80cj5
prolly a stupid question but did you put your anti rattle clips back on?
1989 yj 4.2L, 3" rough country lift, 2" body, 1.5" shackle lift, sye, 35x12.5 cooper discovery stt's, costom rear bumper with d ring mounts, 4 brl holley 390cfm, offenhouser 4brl intake manifold, hollowed out cat, dynomax straight through muffler, t-case out of a ram, 4.11 gears, super dana 35 kit with detroit
80cj5 is offline
post #3 of 8 Old 01-17-2006, 11:46 PM
oct7brian
oct7brian's Avatar
It could be possible you have a damaged but but its usually the calipers or rotors. Did you bleed the system and get all the air out so the calipers aren't hanging up?
1998 Grand Cherokee 5.9 Limited Edition, Upcountry Suspension for Now, Infinity Sound, NP 242 Swap
2002 Jeep Liberty Sport 4x4 3.7L Auto
1998 TJ 4.0 Auto Sahara Package 4" Suspension Lift 33 BFG Hard & Soft Top
oct7brian is offline
post #4 of 8 Old 01-18-2006, 06:37 AM Thread Starter
jeepinjc
jeepinjc's Avatar
Yea I bled the lines but maybe I didnt do it right anyone have a write up on it. I am not sure what you mean by anti rattle clips
jeepinjc is offline
post #5 of 8 Old 01-18-2006, 09:06 AM
oct7brian
oct7brian's Avatar
When bleeding the system you always work from the caliper/wheel cylinder farthest from the Mast Cylinder and work your way forward
post #6 of 8 Old 01-18-2006, 09:10 AM Thread Starter
jeepinjc
jeepinjc's Avatar
so start on passenger side open bleed valve and let fluid come out till it is steady stream and close it then do drivers side same way
jeepinjc is offline
post #7 of 8 Old 01-18-2006, 09:13 AM
bretm
You'd do pass rear, driver rear; pass front, driver front on the Jeep. You bleed until the stream of fluid is free of air bubbles. If you really want to be good, after you're done bleeding them all, go around and do each one again quickly (one shot on each caliper).
Black '88YJ 4.2L
2.5" Skyjacker, 32x11.5s, 4.11s, Weber, HEI, etc.
bretm is offline
post #8 of 8 Old 01-18-2006, 09:46 AM
blake989
How would air in the line hang the caliper? Make sure you re-greased the caliper bolts with some high-temp grease, also make sure you didn't tighten the shat out of them, those bolts barely need tightening. Other than that, make sure nothing is jambed in there that could prevent the caliper from sliding on knuckle. Also keep in mind, a little uneven wear is normal.
The YJ is no longer my DD. I have sacrificed all future retirement plans for jeep parts. I'm depending on social security!
blake989 is offline
uneven tire wear Jeepzcb09 TJ Wrangler Technical Forum 10 02-02-2010 02:17 PM
Uneven tire wear PHXYJ YJ Wrangler Technical Forum 8 09-14-2009 07:13 PM
Uneven tire wear stump YJ Wrangler Technical Forum 2 04-14-2006 12:24 PM
Uneven Tire Wear 58dDriver TJ Wrangler Technical Forum 1 04-08-2006 02:23 PM
Uneven brake wear? zband TJ Wrangler Technical Forum 2 12-26-2003 05:20 PM
