Under powered 95 yj with a 2.5L - Page 8 - JeepForum.com
post #106 of 116 Old 02-13-2014, 07:24 PM Thread Starter
Firemandan
1979 CJ7
I feel like an idiot now but I gotta figure out how to check and set the timing. When I put the distributor in I just put it in till it fell into place.
Still learning
195? M38
1979 CJ7
1995 YJ
Firemandan is offline
post #107 of 116 Old 02-13-2014, 07:26 PM
bhamdan
how far are you from exit 1? my friends and i usually work on jeeps on saturdays.
bhamdan is offline
post #108 of 116 Old 02-13-2014, 07:36 PM
bhamdan
Still learning
so you replaced the distributor too?
bhamdan is offline
post #109 of 116 Old 02-13-2014, 07:43 PM
bhamdan
you sure you put the plug wires in the right order?
bhamdan is offline
post #110 of 116 Old 02-14-2014, 10:49 AM
bhamdan
Ok. Hopefully someone else can help provide some info. His plug wires are reversed and the engine will not crank when put in the correct order, only when reversed. Timing is soon to be checked. Anything to look for?
bhamdan is offline
post #111 of 116 Old 02-14-2014, 11:08 AM
Que89YJ
The distributor isnt put in right. You need to start and put it in and worry about the sequence. There is no doubt after watching the video.
Que89YJ is offline
post #112 of 116 Old 02-14-2014, 11:09 AM
Que89YJ
Set the timing to point at number 1. Remember you can put it 180 out so make sure you are on the compression stroke. Then put the firing order right.
Que89YJ is offline
post #113 of 116 Old 02-16-2014, 11:20 PM Thread Starter
Firemandan
1979 CJ7
I put #1 at TDC and re done the wires so they are correct, wont start now. I was thinking about the crankshaft position sensor, if its bad, wont it give me the signs I'm getting?
195? M38
1979 CJ7
1995 YJ
post #114 of 116 Old 02-17-2014, 05:21 AM
Que89YJ
It can be at #1 2 times. once for compression and the other for exhaust. If you have spark and no start you are probably on exhaust. Pull the #1 plug and put your finger over the hole. Feel if you are getting the air pushing against the finger as you turn the crank.
Que89YJ is offline
post #115 of 116 Old 02-17-2014, 01:54 PM Thread Starter
Firemandan
1979 CJ7
SHE IS ALIVE!!!!!!!
I did have the timing out 180.
I fixed that. put in a new CPS and the ol'e girl fired right up, no hard start or anything.
Drove around the loop and she drove like a champ, very pleased with the way she runs.
Thanks Que for all your help and patients. and everyone else who has been keeping up and giving me some ideas.
195? M38
1979 CJ7
1995 YJ
post #116 of 116 Old 02-17-2014, 04:01 PM
Que89YJ
Good peeps here on the forum. Glad it's running.
Fault codes:
Mean Max pics of everything:
No Start:
Que89YJ is offline
