Under powered 95 yj with a 2.5L - Page 7 - JeepForum.com
post #91 of 116 Old 02-11-2014, 01:23 PM Thread Starter
Firemandan
1979 CJ7
Yeah Que, still have a very hard start.
I haven't replaced the tps but I have replaced the O2 sensor.
195? M38
1979 CJ7
1995 YJ
Firemandan is offline
post #92 of 116 Old 02-11-2014, 01:25 PM
Que89YJ
The tps does fit but I thought you checked it?
Fault codes:
Mean Max pics of everything:
No Start:
Que89YJ is online now
post #93 of 116 Old 02-11-2014, 01:29 PM Thread Starter
Firemandan
1979 CJ7
No, I haven't touched the tps , never seen a code for it so I thought it was ok.
I might as well replace it and see what happens.
195? M38
1979 CJ7
1995 YJ
post #94 of 116 Old 02-11-2014, 01:43 PM Thread Starter
Firemandan
1979 CJ7
TPS is on the way, gotta work tomorrow, I'll pick it up Thursday morning and see what happens and report back.
195? M38
1979 CJ7
1995 YJ
post #95 of 116 Old 02-11-2014, 02:22 PM
bhamdan
If the screws for your TPS are rusted like mine were, you will have a good time getting them out. I used a small ratcheting screwdriver if I remember correctly. I should have replaced the rusty screws but was in a hurry.
bhamdan is offline
post #96 of 116 Old 02-13-2014, 08:16 AM Thread Starter
Firemandan
1979 CJ7
ok, unhooked the battery, replaced the TPS, hooked the battery back up and fired her up.
Still hard to start and still cutting out at 3000rpms.
195? M38
1979 CJ7
1995 YJ
post #97 of 116 Old 02-13-2014, 08:32 AM
Que89YJ
Can you post a video of it cutting out? I want to see exactly what you are dealing with. Post up a link to the video.
post #98 of 116 Old 02-13-2014, 08:50 AM Thread Starter
Firemandan
1979 CJ7
I'll see what I can do
195? M38
1979 CJ7
1995 YJ
post #99 of 116 Old 02-13-2014, 10:21 AM
bhamdan
I wonder if its the PCM... too bad I sold my spare. I also have a 2.5.
bhamdan is offline
post #100 of 116 Old 02-13-2014, 12:44 PM
bmw328rh
did you check timing? it could be the timing is off that happened to me in a saturn and ended up bending most of the valves. but ill tell you one thing in my buddies 2.5 he was having the same sluggish problems and one night it wouldn't start. sounding like a fuel problem i banged on the tank and it started right up. after he took it home he had called me and said that it was running on full power again. my thoughts on that were theres was a lot pf debris and dirt in the sock of the fuel pump and when i banged on the tank with the hammer it shifted the dirt around away from the sock and let the pump suck up the correct amount of fuel again. so i would check your fuel pump sock to see if it is clogged up and if it is try and clean the tank out best as possible put a new sock on it and see what happens.
bmw328rh is offline
post #101 of 116 Old 02-13-2014, 02:11 PM
Why J?
Why J?'s Avatar
For a $90 diag charge a Jeep dealer will most likely be able to tell you exactly what is wrong with it in an hour or so.
Or you can keep throwing parts at it.
New Project "Pissed Wife"
Phase II 5.3L/4L60e then NV3550
Why J? is offline
post #102 of 116 Old 02-13-2014, 03:18 PM
Que89YJ
I just watched the video. It is a misfire at 3000 rpm. Have you done anything to the distributor before this started? That it's a spark timing issue for sure.
Fault codes:
No Start:
post #103 of 116 Old 02-13-2014, 06:05 PM Thread Starter
Firemandan
1979 CJ7
I did buy a kit that had a coil, distributor cap, rotor and plug wires. That's the only things I've done with that stuff.
195? M38
1979 CJ7
1995 YJ
post #104 of 116 Old 02-13-2014, 07:14 PM
bhamdan
have you changed the plugs? one of mine was crushed to where there was no gap when i bought it.
bhamdan is offline
post #105 of 116 Old 02-13-2014, 07:22 PM Thread Starter
Firemandan
1979 CJ7
Yeah, when put the motor together I put in those big gap platinum plugs but I've changed them out for champion copper plugs
195? M38
1979 CJ7
1995 YJ
