Under powered 95 yj with a 2.5L - Page 5 - JeepForum.com
post #61 of 116 Old 02-07-2014, 10:29 AM Thread Starter
Firemandan
1979 CJ7
ok, ill go and get another one, just replaced it last week or the week before.
195? M38
1979 CJ7
1995 YJ
Firemandan is offline
post #62 of 116 Old 02-07-2014, 10:41 AM
Que89YJ
I remember. it should be under warranty. Weird that you get that fault immeadiately after replacing the air temp sensor. The readings were good on both. It makes no sense.
Que89YJ is offline
post #63 of 116 Old 02-07-2014, 12:28 PM
ronniez
your capacitors on your ecm may be going, i had similar symptoms when the weather was cold and when i changed my ecm they went away. a lot of people just replace the capacitors in the ecm and that helps too search brain surgery in the forum and you will find that. btw when you turn the key before firing her up does the check engine light come right on , if it doesnt then its definately yout ecm
ronniez is offline
post #64 of 116 Old 02-07-2014, 12:58 PM Thread Starter
Firemandan
1979 CJ7
ok, I have a coolant temp sensor on the way, should be here in the morning, I did get a noid light test set.
I'm gonna try the noid light after I get the ect sensor put in and see what I can find out in the injectors.
195? M38
1979 CJ7
1995 YJ
post #65 of 116 Old 02-07-2014, 01:18 PM
Que89YJ
Really curious to see if the injectors are dropping out.How much was the nod light?
Fault codes:
Mean Max pics of everything:
No Start:
Que89YJ is offline
post #66 of 116 Old 02-07-2014, 01:20 PM Thread Starter
Firemandan
1979 CJ7
Ronniez, that's what I'm afraid of, being the ECM. I did some checking on the prices, $195 for rebuild and lifetime warranty.
When I turn the key , the CEL does come on.
195? M38
1979 CJ7
1995 YJ
post #67 of 116 Old 02-07-2014, 01:21 PM Thread Starter
Firemandan
1979 CJ7
I Got a 10 piece kit at advanced for 29.99
195? M38
1979 CJ7
1995 YJ
post #68 of 116 Old 02-08-2014, 01:45 PM Thread Starter
Firemandan
1979 CJ7
OK Que, installed the new ECT sensor, hooked up the battery and fired her up and hooked up the noid light, wife sat in the seat and had her throttle up to 3000rpms, as soon as I hooked up the noid light it was flashing like a strobe. Light never went out, even when it was in the bad zone at 3000. did the same thing on all cylinders none of the injectors cut out.
Wife said as soon as I unhooked the first injector the check engine light came on. I checked the codes and it showed code 27, pretty sure its from being unhooked but that all I have for now.
195? M38
1979 CJ7
1995 YJ
post #69 of 116 Old 02-08-2014, 01:48 PM Thread Starter
Firemandan
1979 CJ7
just an observation from my wife. All the sensors I got from advanced are the ones that I've had to replace. Don't wanna ruffle any feathers but just food for thought.
195? M38
1979 CJ7
1995 YJ
post #70 of 116 Old 02-08-2014, 03:08 PM
bedwards24676
Have you tried unplugging 1 injector at a time while the jeep is idling. Just a suggestion. As you unplug one it should affect your idle. Plug it back up and move on to another one. If you get to one that doesn't make a change in idle. You have found your problem. 5 min test that might be worth your time.
bedwards24676 is offline
post #71 of 116 Old 02-08-2014, 04:13 PM
Que89YJ
You have done fuel pressure and the injectors are not cutting out then the issue has to be with the timing control side of things. We are getting close.
Fault codes:
No Start:
Que89YJ is offline
post #72 of 116 Old 02-08-2014, 05:56 PM Thread Starter
Firemandan
1979 CJ7
Bedwards, it idles fine with no problems, It's a hard crank and when it get to 3000rpms it's like it hits a rev limiter, spits and sputters and drops power.
195? M38
1979 CJ7
1995 YJ
post #73 of 116 Old 02-08-2014, 06:12 PM
bedwards24676
I've been following your thread and Stick with Que he will help you find it. It's just very similar to the problems I'm having. After a lot of trouble shooting and replacing some sensors. I did the unplug injector test. To find out I'm only running on 3 cyls. Misfiring when I get to 3000 RPMS and no power. My injectors are firing but nothing is getting through my #4 injector. Unplugging them was the only way I would have found out. Like I said they were all firing. Que will stick with you and y'all will figure it out. It was just a quick suggestion. Good luck.
post #74 of 116 Old 02-08-2014, 06:14 PM
bedwards24676
And also mine idles perfectly even only running on 3 cyls. I know that doesn't sound possible but it is. Good luck.
post #75 of 116 Old 02-08-2014, 06:51 PM
Overhead
x2, you'll only hear it at some rpm if its only running 3 cyl
Overhead is offline
