Under powered 95 yj with a 2.5L - Page 4 - JeepForum.com
post #46 of 116 Old 01-27-2014, 06:27 PM
Que89YJ
If your sure the guage is good then you either have an issue with the regulator or the fuel pump.
Fault codes:
Mean Max pics of everything:
No Start:
Que89YJ is offline
post #47 of 116 Old 01-27-2014, 06:35 PM Thread Starter
Firemandan
1979 CJ7
Well, I guess I'll go with replacing the regulator.
I gotta work tomorrow, I'll update on results Wednesday.
195? M38
1979 CJ7
1995 YJ
Firemandan is offline
post #48 of 116 Old 01-27-2014, 08:14 PM
lowpatrol
1987 YJ Wrangler
will be waiting my brother is having the same issue
lowpatrol is offline
post #49 of 116 Old 01-30-2014, 08:32 PM Thread Starter
Firemandan
1979 CJ7
Well, Murphey strikes again. Most of you've seen, Alabama got hit with snow and a little ice. Most of the parts stores were closed and the roads have been pretty jacked up, but I did get my cousin today, who happens to own a parts store, they are going to order the regulator for me on Monday and should have it in Tuesday morning so I'll pick it up when I get off Tuesday when I get off shift. I'll post and give the thread an update when I install it and see if that helps. Thanks for all the help so far.
195? M38
1979 CJ7
1995 YJ
post #50 of 116 Old 02-05-2014, 10:37 AM Thread Starter
Firemandan
1979 CJ7
Ok, just got the regulator and put it on. Pressure with key on and not running was 33psi
With it running 35psi and running with the vacuum line off it was 40psi
195? M38
1979 CJ7
1995 YJ
post #51 of 116 Old 02-05-2014, 10:53 AM Thread Starter
Firemandan
1979 CJ7
After 20 minutes, no leak down in pressure, holding at 35ish psi
195? M38
1979 CJ7
1995 YJ
post #52 of 116 Old 02-05-2014, 11:15 AM Thread Starter
Firemandan
1979 CJ7
After almost 45 minutes its dropped down to 30psi
195? M38
1979 CJ7
1995 YJ
post #53 of 116 Old 02-05-2014, 11:50 AM
Que89YJ
Your problem isnt fuel pressure. Is it still acting weird at 3000rpm?
Que89YJ is offline
post #54 of 116 Old 02-05-2014, 12:06 PM Thread Starter
Firemandan
1979 CJ7
Yeah Que, as soon as it hits 3000rpms it's like it's on a rev limiter.
Just drove it around the loop and nothing's changed.
195? M38
1979 CJ7
1995 YJ
post #55 of 116 Old 02-05-2014, 12:41 PM
Que89YJ
You didnt replace the intake air temp sensor. Its almost like you are running out of advance or fuel. I wish you had a noid light to put on the injectors. It would be good to know if the injectors are dropping out at 3000. The older engines had a wide open throttle switch that when it was pushed cut out fuel to clear a flood. The newer obd1 setup uses the tps and the ecu cuts the fuel. It sounds like what you describe. The fuel pressure would stay up but cut the injectors.
Que89YJ is offline
post #56 of 116 Old 02-05-2014, 01:37 PM Thread Starter
Firemandan
1979 CJ7
Ok Que, just ordered a new air temp sensor. I gotta work tomorrow and I'll put it on Friday and post the results.
Thanks again for all the help you and others have given me, just another reason I tell folks that Jeeps aren't just a car, it's a culture.
195? M38
1979 CJ7
1995 YJ
post #57 of 116 Old 02-05-2014, 03:43 PM
Que89YJ
I am really curious about the cut out. Noid lights are cheap.
Fault codes:
No Start:
Que89YJ is offline
post #58 of 116 Old 02-05-2014, 04:21 PM Thread Starter
Firemandan
1979 CJ7
I'll look around for the noid light and see what I can find. I'll update on Friday.
195? M38
1979 CJ7
1995 YJ
post #59 of 116 Old 02-07-2014, 08:55 AM Thread Starter
Firemandan
1979 CJ7
ok, installed the air temp sensor, hooked the battery back up, fired it up let it run for a bit, still cutting out at 3000rpms. drove it around the loop to see if it would get better as it got a little warmer, Check engine light came on and started cutting out at lower rpm's, got it home and it's over heating. inside temp guage never got above 220ish.
pulled the codes and im getting the normal 12, 33 and now a 22 is showing up.
Gonna run by the store and check on that noid light and check the injectors.
195? M38
1979 CJ7
1995 YJ
post #60 of 116 Old 02-07-2014, 10:14 AM
Que89YJ
Coolant temp sensor? The only reason for it to light the cel is because it is out of range. It is the same sensor as the air. Spend the 20 and replace it.
Que89YJ is offline
