Under powered 95 yj with a 2.5L - Page 2 - JeepForum.com
post #16 of 116 Old 01-25-2014, 09:15 PM
Firefyter-Emt
Yea, that's not right... I have the same set uo, but with some smaller 30's on mine for now. I can pretty much hold 70 on the highway in 5th with the same exact set up... I even hit 85 once (once!) But she's a bit slow, but I am fine with that really... she's not a race car! However, I have no problems keeping up with cars driving around me.
For what it's worth, I am also running a 4.0L TB and a 2.5" PaceSeter cat back exhaust. Those two mods did help quite a bit with the highway end of things.
Firefyter-Emt is offline
post #17 of 116 Old 01-25-2014, 10:41 PM
Richard_
mine has 30x9.5's and has no problem holding speed as well , it takes a bit to get there , but as long as the road is flat and no headwind , all is good
Richard_ is offline
post #18 of 116 Old 01-26-2014, 10:40 AM Thread Starter
Firemandan
1979 CJ7
Que, ran the codes and it's showing,
12
33
17
55 end of codes
fuel pressure with key on was @35ish PSI
motor running was 40PSI
195? M38
1979 CJ7
1995 YJ
Firemandan is offline
post #19 of 116 Old 01-26-2014, 12:35 PM
Que89YJ
Both will effect your power. Running too cool is the fault code. The temp sensor and tstat should both be replaced. The fuel pressure at 40 running. Was that with the vacuum line disconnected? Did you check to see if you held pressure above 20 psi for longer then 20 minutes when shutting it off?
Fault codes:
Mean Max pics of everything:
No Start:
Que89YJ is offline
post #20 of 116 Old 01-26-2014, 12:54 PM Thread Starter
Firemandan
1979 CJ7
I checked after more than 20 minutes and it only dropped 10PSI, it was at 30PSI when I checked.
Didn't pull the vacuum line while it was running, I can go and do it again
195? M38
1979 CJ7
1995 YJ
post #21 of 116 Old 01-26-2014, 02:32 PM Thread Starter
Firemandan
1979 CJ7
I swapped out both the tstat and the temp. sensor last week. I was gonna drive it to get the tag and it ran hot about a half mile from home, let it cool down and I drove it home and swapped out the TStat and the temp sensor because it was showing it was still hot on the gauge. I put the new sensor in and now it doesn't move from cold temp reading. I didn't reset the codes by removing the battery cable, I'm going to do that right now and re read the codes and see what happens
195? M38
1979 CJ7
1995 YJ
post #22 of 116 Old 01-26-2014, 02:39 PM Thread Starter
Firemandan
1979 CJ7
ok, ran the codes again
12
33.
34 PSI with key on and not running
40 PSI running and what looks like 42PSI with the vacuum line off the fuel regulator.
also noticed that @ 3000RPMs the motor sputters and spits, she acts like she doesn't wanna go any higher.
Injectors????
195? M38
1979 CJ7
1995 YJ
post #23 of 116 Old 01-26-2014, 02:46 PM
Que89YJ
Wrong temp sensor the one you want to replace its the one near the tstat. Your fuel pressure is high too. If the guage is correct. Since you are 10 psi high check to make sure you have good vacuum on the line going to the regulator.
Fault codes:
No Start:
Que89YJ is offline
post #24 of 116 Old 01-26-2014, 02:47 PM Thread Starter
Firemandan
1979 CJ7
after shut off pressure held @ 28PSI little over 20 minutes
195? M38
1979 CJ7
1995 YJ
post #25 of 116 Old 01-26-2014, 03:28 PM
Que89YJ
Fuel pressure it's definitely wrong. Check the vacuum line at the pressure regulator. Did the pressure change when you disconnected it?
Fault codes:
No Start:
Que89YJ is offline
post #26 of 116 Old 01-26-2014, 04:21 PM Thread Starter
Firemandan
1979 CJ7
When I took the vacuum line off it didn't change.
The L shaped boot that connects the regulator with the vacuum line is dry rotted.
195? M38
1979 CJ7
1995 YJ
post #27 of 116 Old 01-26-2014, 04:35 PM
Jeepsr4me
fix the vacuum line... And recheck pressure
Jeepsr4me is offline
post #28 of 116 Old 01-26-2014, 05:14 PM Thread Starter
Firemandan
1979 CJ7
Fixed vacuum line
Key on, not running 35psi
Running. 36psi
Running without vacuum line 42psi
195? M38
1979 CJ7
1995 YJ
post #29 of 116 Old 01-27-2014, 09:27 AM Thread Starter
Firemandan
1979 CJ7
I drive it around the neighborhood and still the same thing, kind of like its hitting a rev limiter at 3000rpms , spits and sputters. I'm gonna go and get a new tstat, engine coolant temp sensor and the other temp sending unit. Anything else?
195? M38
1979 CJ7
1995 YJ
post #30 of 116 Old 01-27-2014, 10:40 AM
Firefyter-Emt
What about the simple stuff? Plugs, wires, cap & rotor...
