Under powered 95 yj with a 2.5L - JeepForum.com
post #1 of 116 Old 01-23-2014, 10:19 PM Thread Starter
Firemandan
1979 CJ7
Ok Folks, as some of you know, I've just finished with my 95 yj to use as a daily driver. As I took it out for it's victory drive around the community, I noticed it was VERY under powered. It's a rebuilt 2.5L, 5 speed with 31" tires. She's real slow on take off. RPM's are pretty low " I think they are low"
I'm not an expert. I have to drop down to 2nd for some of the small inclines in the area. on flat road, I can get it up to 48-52MPH and that's as fast as I have gotten her. Just asking what could it be?
Is it gears?
a sensor?
the moon not being aligned with mars?
Help please
195? M38
1979 CJ7
1995 YJ
Firemandan is offline
post #2 of 116 Old 01-23-2014, 10:21 PM Thread Starter
Firemandan
1979 CJ7
OH one of the most important things...........stock 4:10 gears
195? M38
1979 CJ7
1995 YJ
post #3 of 116 Old 01-24-2014, 04:16 AM
Que89YJ
Start with your codes.
http://www.jeepforum.com/forum/f12/h...codes-1257145/
Fault codes:
Mean Max pics of everything:
No Start:
Que89YJ is offline
post #4 of 116 Old 01-24-2014, 08:24 AM
Jeepsr4me
Yeah computer could be gone or exhaust is stopped up.. Many things. But these little engines like to rev, so that should not be a issue.
Jeepsr4me is offline
post #5 of 116 Old 01-24-2014, 11:15 AM
EABiker
Does it run the same cold as it does when warmed up? The sensors really only come in to play after it reaches operating temperature. I would first look for a vacuum leak, especially around the intake manifold.
EABiker is offline
post #6 of 116 Old 01-25-2014, 07:36 AM Thread Starter
Firemandan
1979 CJ7
EAB, it runs the same at operating temp as it does cold.
I'm at the station today so I'm gonna check the codes out tomorrow when I get home.
I should mention that I do have a screaming demon coil and live wires with big gap plugs on it, just thought I should mention that.
Also, she's VERY cold natured, takes a bit to get her to start and after she's been run for a bit and sits for a few minutes she is slow to start.
Not sure if it could be a timing issue, what do y'all think?
195? M38
1979 CJ7
1995 YJ
post #7 of 116 Old 01-25-2014, 08:16 AM
Jeepsr4me
check your fuel pressure
post #8 of 116 Old 01-25-2014, 08:36 AM Thread Starter
Firemandan
1979 CJ7
Thanks jeeps, I'll check that in the morning.
Good thought.
195? M38
1979 CJ7
1995 YJ
post #9 of 116 Old 01-25-2014, 09:18 AM
Que89YJ
Fuel pressure. 31 psi drinking. 39 psi after disconnecting the pressure regulator vacuum hose. Turn the key off. Pressure should stay above 20 for 20
Fault codes:
No Start:
Que89YJ is offline
post #10 of 116 Old 01-25-2014, 10:00 AM
plumber1
It's not gears, when my 2.5 YJ was on 31's I could go 65+ on the freeway on the flats w/o much problem. Now when I got to inclines it did suffer but never on the flats, it's no racer but I agree with the others you have something else going wrong.
I can quit drinking anytime I want, but hey I'm no quitter :)
White Jeep Club #224
plumber1 is offline
post #11 of 116 Old 01-25-2014, 10:14 AM
flcracker
2.5, 5 spd, 4.10's and it gets up and goes just fine.... only had it on the Interstate once and it did 70, took a while to get there but it did 70....
edit: this was on 31's
Not the sharpest bulb in the box....
My Jeep is possessed with the goal of making me lose my religion....
flcracker is offline
post #12 of 116 Old 01-25-2014, 02:19 PM
Kowalski
Maybe it's the catalytic converter? Mine was stopped up and felt sluggish.
Kowalski is offline
post #13 of 116 Old 01-25-2014, 02:30 PM Thread Starter
Firemandan
1979 CJ7
I put a new exhaust system on it, not saying it couldn't be the cat but Ill check.
195? M38
1979 CJ7
1995 YJ
post #14 of 116 Old 01-25-2014, 07:42 PM
Que89YJ
Fault codes?
Fault codes:
No Start:
Que89YJ is offline
post #15 of 116 Old 01-25-2014, 08:27 PM Thread Starter
Firemandan
1979 CJ7
Que, I haven't ran the codes yet, gonna do it in the morning when I get home.
195? M38
1979 CJ7
1995 YJ
