under hood toolbox - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > under hood toolbox
FS: Wranger BRIGHT License Plate LED! Just $3! Great valueRIGID LED Light Blowout Sale - All Sizes, All Series, all End of Summer Sale, 20% OFF!
Unread 09-04-2014, 12:09 AM   #1
tazmangk
under hood toolbox
Was wondering if anyone has mounted a tool/storage box on passenger fender where the now useless stock jack was mounted? If so pics? Ideas?
tazmangk is offline   Reply With Quote
Unread 09-04-2014, 01:49 AM   #2
jay-h
I mouted one on the driver's side. Very handy.
My toys
'89 Wrangler YJ
'47 CJ2-A
wife's toys
97 Grand Cherokee (ZJ)
87 MB 560SL roadster
jay-h is offline   Reply With Quote
Unread 09-04-2014, 01:50 AM   #3
GunHo198
My son did the windstar air intake on his TJ and I converted his factory air box into a tool box. I trimmed the old air filter to use as a gasket to keep it water tight and sealed the big open hole with a spray can lid. It looks factory. I did the same windstar intake on my YJ, but till I find a factory air box then I'll do the same. He keeps working gloves and his winch remote in his air/tool box. He doesn't use his winch remote very often as we converted ours to wireless. But it's good to still carry them for emergencies.
94 Jeep Wrangler 4.0 with AX-15 Trans.
4" Procomp Lift, 3" body lift, 35" BFG Tires, Ford 9" Rearend with NASCAR Detroit Locker, Super 30 Front with ARB, Onboard Air, Dual Optima Batteries,Warn M8274 Winch, and Bushwacker Fender Flares.
GunHo198 is offline   Reply With Quote
Unread 09-04-2014, 04:22 AM   #4
jay-h
What are you using instead of a stock jack? I've been considering a bottle jack, though I'd still put it in the same place.
My toys
'89 Wrangler YJ
'47 CJ2-A
wife's toys
Unread 09-04-2014, 05:13 AM   #5
grandboost98
Like so?
89 Jeep Wrangler - 3.5" HD BDS lift and M.O.R.E. HD 5/8" booms on 33s
99 Jeep Cherokee - 2 door, 5" lift on 33" super swampers
72 Chevy Nova - build in progress
98 Pontiac Grand Prix GTP - too many mods to list::SOLD::
grandboost98 is offline   Reply With Quote
Unread 09-04-2014, 05:59 AM   #6
Old4X
1990 CJ7
Many here have mounted a GI ammo can there for a tool box.
418 miles on 19 gallons of gas. Can't beat the BBD !
Old4X is offline   Reply With Quote
Unread 09-04-2014, 08:08 AM   #7
jay-h
Originally Posted by grandboost98 View Post
Like so?
Looks good!
My toys
'89 Wrangler YJ
'47 CJ2-A
wife's toys
Unread 09-04-2014, 08:29 AM   #8
jbolty
jbolty's Avatar
small size ammo box fits there fine but I didn't like it. It's heavy on the fender if you fill it with tools. Plus everything in there has to stand the heat of the engine.
If you live within wheeling distance of San Diego county, click here
jbolty is offline   Reply With Quote
Unread 09-04-2014, 09:24 AM   #9
tazmangk
I use a high lift, just hate dragging it around, have considered a bottle jack under the hood.....mostly just thinking about some extra storage.
Unread 09-04-2014, 09:35 AM   #10
Old4X
1990 CJ7
My bottle jack rides in my center console.
The best tool storage I have seen was the tool locker under the passenger's seat on the old Willys Jeeps.
Unread 09-04-2014, 10:36 AM   #11
superj
1987 YJ Wrangler
i put a regular old ammo can in the stock jack place. i used the jack mount and aligned the box to where the lid closed and hten welded hte can to the mount. its tiled a little so stuff doesn't fall out when you open the lid and it holds a ton of stuff. i put oil and under hood junk in it.
Slow ride, take it easy
superj is offline   Reply With Quote
Unread 09-04-2014, 10:46 AM   #12
jay-h
Be careful. They're not the safest for tire changing as others have noted. I've seen a Jeep fall off one. .. no one was hurt but the Jeep was damaged.
My toys
'89 Wrangler YJ
'47 CJ2-A
wife's toys
Unread 09-04-2014, 10:54 AM   #13
jay-h
Most tools (including plastic handle screwdrivers) are completely unbothered by the heat. But don't put your spray can of WD 40 there, however.
My toys
'89 Wrangler YJ
'47 CJ2-A
wife's toys
Unread 09-04-2014, 10:59 AM   #14
HaskiE
Thread Reviver
HaskiE's Avatar
I did this, and it works great for Jumper cables, Bottlejack, rags & a few things.
the rags & cables keep everything from rattling around and all you have to do it open it and you can angle it out of there. been installed for 4 years, no issues.
In Hindsight, maybe not cutting holes in the box would have been better, but I never have had a problem with it getting too hot either - maybe those holes are giving it good ventilation.
lots of good Ideas here:
http://www.jeepforum.com/forum/f12/i...f-here-457361/
#theneverendingaxe
HaskiE is offline   Reply With Quote
Unread 09-04-2014, 05:31 PM   #15
Delawdude
Delawdude's Avatar
I like the tool box setup, what size is it?
Delawdude is offline   Reply With Quote
