Under Driver Seat - what is it? - Page 2 - JeepForum.com
post #16 of 21 Old 08-30-2014, 03:31 PM
sprngrider
It is very cool. When the outer radar is triggered, the warning chirp is activated. When the inner radar is triggered, the alarm goes off. Works great for convertibles.
1994 2.5L WRANGLER S.
sprngrider is offline
post #17 of 21 Old 08-30-2014, 04:40 PM
Cobra Jeep
Originally Posted by TomYJ View Post
It's only bolted to the bracket, not connected to anything else under seat. The wiring disappears into large harness coming through firewall under dash.
Attachment 1574674
That is the acceleration sensor for your ABS brakes. It lets the ABS computer know if your stopping real fast and how hard. Its basicly a mecury switch.
'93 YJ 4.0L, AX-15, NP-231HD/SYE, 8.8in rear, OME 2.5 lift, home made front hub conversion, hydroboost. Warn M10000 winch. Currently building a stroker.
'79 Cherokee Chief, 401 MPFI fuel injection, T-18/D-20 and hydroboost. Otherwise stock.
Cobra Jeep is offline
post #18 of 21 Old 08-30-2014, 04:51 PM Thread Starter
TomYJ
ABS disconnected when Dana 44 was installed - sounds like it's ok to disconnect. Do I just terminate the wires under the dash?
Thanks for the help!
TomYJ is offline
post #19 of 21 Old 08-30-2014, 05:29 PM
Mambo_Dave
Originally Posted by BRC_1980 View Post
I thought it was seatbelt related too but checked mine and it doesn't look like that. I also have a weird thing I found when removing my carpet.
I have a box that looks like that, though mine was just some alarm and ignition cut-off box that only cut the ignition off after someone ... like me ... disconnected, then reconnected, the YJ's battery.
Totally useless, so I found a way to bypass it.
Mambo_Dave is offline
post #20 of 21 Old 08-30-2014, 05:52 PM
bigPapaLapas
I have the exact same box for my viper alarm.
bigPapaLapas is offline
post #21 of 21 Old 08-31-2014, 06:32 AM
mrmud4x4
Maybe the alarms are hooked up here because of it's location and access to power?
(see...I told you it was a tilt switch...lol...so if you flip over, you can't use your brakes either....)
This forum requires that you wait 60 seconds between searches. Please try again in 1 seconds.
mrmud4x4 is offline
