under dash plug identification - JeepForum.com
post #1 of 44 Old 06-28-2013, 08:42 PM Thread Starter
kjg26
kjg26's Avatar
Ok I have sourced an uncut harness and put them side by side with my hacked harness. I believe I have everything hooked back up as it should be. I would like some clarification if you all don't mind. These are all under the dash of the passenger side of my 93 YJ, at the furthest end of the harness.
I found a diagram of dash wiring floating around here somewhere but it didn't really match mine.
I also understand there are going to be several plugs that will not be used from options that my jeep doesn't have. (AC, hard top, etc).
The speaker plugs are confusing to me, as I have looked on and spoke with METRA regarding their harness adapters and none look like they will fit.
All the wires i'm working with
starting from the closest to the fuse box (in this picture) and moving out towards the passenger side.
above and below are the same connector, just diff angles
PASS SIDE DOOR SWITCH
HEATER/VENT BOX: sticks straight into the connectors sticking out of the face of the box
ON TOP OF THE BLOWER MOTOR (PASS SIDE OF DASH)
I believe I have these two plugged in correctly as demonstrated in this photo
and these are at the furthest end of the harness
RIGHT PLUG (FACTORY PASS SIDE DASH SPEAKER)
LEFT PLUG (SOUND/LIGHT BAR WIRING)
Black 1993 YJ 4.0, 5 Speed
Slowly but surely getting better and better. Trailer build soon!!
kjg26 is offline
post #2 of 44 Old 06-28-2013, 08:48 PM Thread Starter
kjg26
kjg26's Avatar
here are the two metra wiring harness that their website suggests for the speakers.
72-1002
70-1002
the second one is listed as jeep/eagle 4 speaker power. I just don't see where either of these harness's will plug into the stock dash wiring.
kjg26 is offline
post #3 of 44 Old 06-29-2013, 11:25 AM
XJ93
Those aren't speaker wires.
XJ93 is offline
post #4 of 44 Old 06-29-2013, 11:32 AM
XJ93
That single wire looks like the one on my YJ that goes to the dome light switch in the door jamb.
XJ93 is offline
post #5 of 44 Old 06-29-2013, 11:33 AM
bigbossd1030
I can help a little bit.
Pictures 6 (single female spade connector) and 7( three female spade connectors).
Number 6 if for the door switch I do believe, activates the dome lights and buzzer when the door opens. And number 7, is for the blower motor resistor. I will check mine after some running around I have to do, see if I can find those other ones. I have seen them when I did my blower motor, just can't remember.
Sent from my iPhone, probably because I am bored at work.
/l ,[____],
l----L-[]lllllll[]-
()_)-()_)--o)_)
OFFICIAL JEEPER
Any Jeepers in Edmonton, AB
I am on channel 33.
I live, I ride, I am JEEP.
bigbossd1030 is offline
post #6 of 44 Old 06-29-2013, 02:24 PM Thread Starter
kjg26
kjg26's Avatar
Which single wire are you referring to?
kjg26 is offline
post #7 of 44 Old 06-29-2013, 02:28 PM
bigbossd1030
The one with the spade connector
/l ,[____],
l----L-[]lllllll[]-
()_)-()_)--o)_)
OFFICIAL JEEPER
I am on channel 33.
post #8 of 44 Old 06-29-2013, 08:01 PM Thread Starter
kjg26
kjg26's Avatar
bigboss have you have a chance to poke your head under the dash. Any chance you can snap a couple pictures, i'd like to tuck it up there and secure everything as close to factory as possible.
Thanks. I'll PM you my email adress and phone number, on the off chance you can help me out with this. whichever works for you.
kjg26 is offline
post #9 of 44 Old 06-29-2013, 08:41 PM
bigbossd1030
Indeed.
#'s below are picture numbers in your first post.
#3 and 4 are for the dome lights, The bulbs themselves, not the switch.
#5 and 6 are for the door ajar pin.
#7 and 8 are in the correct positions in your photo. (7 is resistor) 8 (not sure)
In your last pic, I don't have the one on the right, Only the left. But it goes to the over head speakers (speaker bar) Those are speaker wires.
/l ,[____],
l----L-[]lllllll[]-
()_)-()_)--o)_)
OFFICIAL JEEPER
I am on channel 33.
post #10 of 44 Old 06-29-2013, 08:46 PM
bigbossd1030
Email sent as well
/l ,[____],
l----L-[]lllllll[]-
()_)-()_)--o)_)
OFFICIAL JEEPER
I am on channel 33.
post #11 of 44 Old 06-29-2013, 09:49 PM Thread Starter
kjg26
kjg26's Avatar
first post last picture. I believe be the speaker wires for the dash speakers.
kjg26 is offline
post #12 of 44 Old 06-29-2013, 09:53 PM
bigbossd1030
Mine goes to a connector on the door jamb that goes under the door jamb and up the roll bar.
/l ,[____],
l----L-[]lllllll[]-
()_)-()_)--o)_)
OFFICIAL JEEPER
I am on channel 33.
post #13 of 44 Old 07-01-2013, 07:43 AM
XJ93
I was referring to the only single wire connector that you have pictured. Pics 5 and 6.
XJ93 is offline
post #14 of 44 Old 07-01-2013, 08:22 PM Thread Starter
kjg26
kjg26's Avatar
Ok. One more and I think I've got them all figured out.
This is just to the passenger side of the steering column. On my factory wiring its all hacked up. On the replacement wire its....
kjg26 is offline
post #15 of 44 Old 07-01-2013, 08:49 PM
bigbossd1030
I'd have to crawl under a look for that one. Not sure at all, ill check it out tomorrow at work, see if I can find it. If someone doesn't know before I find out.
/l ,[____],
l----L-[]lllllll[]-
()_)-()_)--o)_)
OFFICIAL JEEPER
I am on channel 33.
