Undecided with my jeep - JeepForum.com
post #1 of 4 Old 06-01-2005, 09:24 PM Thread Starter
virtuaillusion
Here's the bad news mothers day i rolled my jeep(94 4.0 w/96,000 miles). My buddy that is a mechanic said that to get it on the road i have to replace the windshield and windshield frame, rear passenger leaf springs and the roll bar and maybe tires. Here is where i am undecided I also have a 90 yj with the 4.2 that i was having engine problems that i could swap the engine and wiring harness into it. The 94 has some extensive body damage on all sides so what would you guys do. repair the body or swap the engine. Which would be more economical. Thanx for the help before hand.
Kris
virtuaillusion is offline
post #2 of 4 Old 06-01-2005, 10:00 PM
Punisher
Probably cheaper + easier to just swap the newer drivetrain into the older jeep. Use the good parts from the 94 and sell the rest. Build up the older one with the money you make from the salvage parts.
Punisher is offline
post #3 of 4 Old 06-01-2005, 10:01 PM
GreenDean
GreenDean's Avatar
I Conquer!
GreenDean is offline
post #4 of 4 Old 06-01-2005, 10:21 PM
mYJ
Depending on emissions laws where you are from.... Usually you can swap a newer motor into an older vehicle but not the other way around. As said, you might be better off fixing up the 90.
-Jeffrey-
92 YJ 2.5, OME, Flat Fendered, 31" Big O XTs, Crager Soft 8s, Posi-Lok, no sway/track bars, Exide Orbital, K&N, 4.0 TB & TBS, Mopar Performance Cam, Glass pack & Hi-Flow cat, Grant GT Removable Wheel, Tuffy Console, Other Stuff.
Black JeepClub V2.0 #33 - Me & Roy
mYJ is offline
undecided on shocks.... gamble3527 TJ Wrangler Technical Forum 7 08-10-2009 01:38 PM
undecided on what all terrains to go with mossman07 TJ Wrangler Technical Forum 29 02-15-2009 03:24 PM
Undecided on LA and SF again...HELP! wrangler2007 TJ Wrangler Technical Forum 3 11-15-2008 03:16 PM
Undecided: 33 or 30 Spline D44 Humboldt TJ Wrangler Technical Forum 15 09-17-2007 04:00 PM
lifts- undecided need ideas mule-brothers YJ Wrangler Technical Forum 12 05-29-2001 02:39 AM
