Un biased cheap lift review comming soon from a seasoned Jeeper - Page 4 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > Un biased cheap lift review comming soon from a seasoned Jeeper
Want to be able to SEE? DOT Approved Headlights for under Coil Spring Options from Ruffstuff!Flush Mount LED Bumper Lights, CREE
Unread 02-20-2014, 04:33 PM   #46
ssyj94
You having trouble with the spring hanger bolts? They like to rust to the sleeves in the leaf spring bushings. Easiest way to deal with them is cut the head and threads off with a grinder. Then pry them out of the hanger, it takes 5 minutes each bolt.
Link locked and ready to rock
Http://www.jeepforum.com/forum/f12/y...lovers-1121183
ssyj94 is offline   Reply With Quote Quick reply to this message
Unread 02-20-2014, 05:18 PM   #47
Tom95YJ
[] Eye'd Jeep Connoisseur
Tom95YJ's Avatar
I'm just gonna wait a couple weeks and do it at my buddy's shop so I can use a lift and have access to pretty much every tool known to man
'89 YJ The Smurf Build Thread
'99 XJ Black Betty Build Thread
Tom95YJ is offline   Reply With Quote Quick reply to this message
Unread 02-20-2014, 06:34 PM   #48
ssyj94
That's overkill. Its a YJ a lift is easily done with basic hand tools, jack/stands, bfh, cheater pipe and a grinder.
Seriously cut everything out(ubolts, hanger bolts and trac bar junk) it'll save you a ton of time and effort. Only special tool you really need is a pitman arm puller.
Unread 02-20-2014, 06:49 PM   #49
Tom95YJ
Tom95YJ's Avatar
That's overkill. Its a YJ a lift is easily done with basic hand tools, jack/stands, bfh, cheater pipe and a grinder. Seriously cut everything out(ubolts, hanger bolts and trac bar junk) it'll save you a ton of time and effort. Only special tool you really need is a pitman arm puller.
I don't have trackbars or swaybars Having access to a lift And more room is much easier then a small 1 car garage where there is barley any room to work. And I won't have my wife or kids bugging me every 10 minutes or every time they hear a noise.
Unread 02-21-2014, 08:51 AM   #50
bgredjeep
1987 YJ Wrangler
But we want to see and hear the results MEOW!
Seriously though, I am interested to hear how this lift rides. Looks like a nice option for my wife's Jeep if it does well.
bgredjeep is online now   Reply With Quote Quick reply to this message
Unread 02-21-2014, 04:36 PM   #51
Richard_
the suspense is killing me !!!
Richard_ is offline   Reply With Quote Quick reply to this message
Unread 02-21-2014, 05:26 PM   #52
Anticanman
Follow me
Anticanman's Avatar
I'm anticipating the disappointment!
Luck Favours The Prepared
[SIGPIC][/SIGPIC]
Anticanman is offline   Reply With Quote Quick reply to this message
Unread 02-21-2014, 05:30 PM   #53
justanotherjpr
Subbed!
So do you actually hear your thoughts in your head or is it just sort of a dull roar before you smash your face into your keyboard and just submit whatever dumb **** ended up on the page?
justanotherjpr is offline   Reply With Quote Quick reply to this message
Unread 02-21-2014, 05:53 PM   #54
Mambo_Dave
The short-term review isn't why I'm subscribing... it will be the review 4 years from now that I want exact measurements at all four corners to see if they sagged.
My bet is you probably aren't going to keep the Jeep that long. From what I've seen on Craigslist a lot of people buy the cheap lifts to try to make a buck or hype them up to sell them.
Mambo_Dave is offline   Reply With Quote Quick reply to this message
Unread 02-21-2014, 07:06 PM   #55
Tom95YJ
Tom95YJ's Avatar
Originally Posted by Mambo_Dave
The short-term review isn't why I'm subscribing... it will be the review 4 years from now that I want exact measurements at all four corners to see if they sagged. My bet is you probably aren't going to keep the Jeep that long. From what I've seen on Craigslist a lot of people buy the cheap lifts to try to make a buck or hype them up to sell them.
This jeeps not going anywhere. I had my last YJ for 8 years and regretted selling it everyday until I got this one. In 4 years this will probably be Soa on full width axles
Unread 02-21-2014, 08:08 PM   #56
jaycal3
Why is everyone acting like this lift hasn't been reviewed in an "unbiased" way before this?? Its RC people... you get what you pay for and to many it will be ok.... for a while... maybe...
93 YJ, 6 cyl,3.5" BDS,1" Prothane BL,1/2" booms
Do your part for Leukemia research - help find a cure.
http://mskcc.convio.net/goto/Jay_Calabrese
KCCO
jaycal3 is offline   Reply With Quote Quick reply to this message
Unread 02-21-2014, 11:37 PM   #57
Tom95YJ
Tom95YJ's Avatar
Cause this is not the normal rc lift this is their new x series with military wrap springs
Unread 02-22-2014, 07:00 AM   #58
Mambo_Dave
Did they specify that there was something different about the metallurgy, and/or where the springs were made (so where the steel was sourced from), or are these really just everyday old RC springs with military wraps?
Unread 02-22-2014, 09:44 AM   #59
Tom95YJ
Tom95YJ's Avatar
They specified that they designed the springs specifically for the YJ To give a soft ride and flex. Articulate well off road. The N20 shocks are specifically valved for the YJ also according to their rep.
Unread 03-10-2014, 10:17 AM   #60
Tom95YJ
Tom95YJ's Avatar
I got some time set aside to use my buddy's shop so the springs will be going on Friday evening I'll start the review then
