The Ultimate Coolant Temp Sender/Sensor Thread Once and For All - Page 3 - JeepForum.com
post #31 of 34 Old 09-15-2011, 09:59 AM
Berniebikes
for you one of the sensors will be signalling your ECM and connected to Pin C10 on the ECM, one will be for the manifold heater (single wire sensor) and the one on the back by the fire wall should be the signalling unit for the gauge (also with a single wire). Glad it helped, old post but useful info.
Berniebikes is offline
post #32 of 34 Old 03-08-2013, 01:17 PM
tylerthebike
My gauge has started jumping around a bit. I accidentally bought the sensor that goes into the thermostat housing, so now I've got the right one in the mail, but does anyone know where I can get a new female end? Looks like the previous owner already did a bit of splicing and I would rather just start fresh.
tylerthebike is offline
post #33 of 34 Old 03-08-2013, 05:06 PM
jokerchief462
If you are looking for the connector check your local parts house. They should have a solution.
89YJ 2.5L TBI, AX-5, NP231 SYE, Ford 8.8, Yukon Grizzly, Tom Woods Shaft, 33" BFG T/As, 4" lift, Warn VR10000s.
AF Jeep Club Tail #184
jokerchief462 is offline
post #34 of 34 Old 05-01-2013, 01:09 PM
Oper8or
I'm glad this info is here. I almost bypassed the wrong one.
Oper8or is offline
What voltage at coolant temp sender? UnderDog! YJ Wrangler Technical Forum 0 10-01-2009 08:28 PM
Coolant Temp Switch (Sender) rmorrison9773 YJ Wrangler Technical Forum 0 06-01-2009 07:17 AM
2.5 Coolant Temp Sensor Thread Size? Thee_Nickster YJ Wrangler Technical Forum 1 04-20-2009 09:27 AM
New coolant temp sender with Carter carb traumajunkey YJ Wrangler Technical Forum 2 03-24-2009 04:09 AM
Temp Sensor / Coolant Temp Sending Unit malone_ge YJ Wrangler Technical Forum 1 03-01-2007 09:41 AM
