The Ultimate Coolant Temp Sender/Sensor Thread Once and For All - Page 2 - JeepForum.com
post #16 of 34 Old 08-23-2008, 02:18 PM Thread Starter
fgcox1
Youse guys are all genius'es!!!!
It is on the drivers rear (ouch!) and was broken off, looking just like a bolt head. Muddy93, you de man!
Unscrewed and replaced, it works great.
I do think it is interesting that the 93 YH FSM is wrong. I wonder how many folks have been led astray?
Anyway, I owe each of you a cervesa of your choice if you are ever in Dallas!
Tnx Fred
fgcox1 is offline
post #17 of 34 Old 09-07-2008, 09:35 PM
quadrider21
92 2.5L swaped with 2000 2.5L
I swaped my 92 2.5L engine because the temp senor was broken off
Any ways, the 2000 2.5L doesn't have the same sensor in the head that my 92 did. Any one have a good idea on how I can get a good temp reading with out drilling and tapping the head?
quadrider21 is offline
post #18 of 34 Old 09-07-2008, 11:17 PM
BackRoadJPin
1995 Wrangler
BackRoadJPin's Avatar
if this motor is out of a 2000 Wrangler then it is not a 2.5L I believe it to be a 2.4L and is a whole different motor.
Back Road Jeepin
BackRoadJPin is offline
post #19 of 34 Old 06-04-2009, 08:33 PM
khurley
I have a 96 cherokee, 4.0 inline 6 cyl. I recently installed a reman, and the whole for the temp guage sending unit is not there. My question is the same, any ideas what I can do to get a reading to my temp guage?
khurley is offline
post #20 of 34 Old 06-04-2009, 08:58 PM
bartolo
if u unplug the sensor temp for the computer will the jeep stall i was mudding and my temp sensor for the computer broke and it was just hanging my jeep 91 yj 4.0 ho stall on me after looking around i found this put it back in place and a few minutes later it start would that be the probem i had?
bartolo is offline
post #21 of 34 Old 06-04-2009, 09:20 PM
Louie4
Possibly. I've had mine unplugged and nothing ever came of it, but I was playing with an XJ one time and I unplugged it and the electric fan came on and would stay on. If the computer can't sense how much fuel to put in the engine it might cause it to have hard starts or not run as efficiently. If you broke it though you should replace it. Its only 14 bucks at autozone. I can't remember how much the coolant temp sender is, I replaced that years ago after I broke it when doing a valve job.
Lou
YJOTM July 2012
YJOTM February 2014
Louie4 is online now
post #22 of 34 Old 06-05-2009, 09:58 AM
khurley
I have a 96 cherokee, 4.0 inline 6 cyl. I recently installed a reman, and the hole for the temp guage sending unit is not there. My question is the same, any ideas what I can do to get a reading to my temp guage?
khurley is offline
post #23 of 34 Old 01-08-2011, 08:03 AM
brentd711
Can someone post a pic of the ECM CTS on a 1990 4-banger?
brentd711 is offline
post #24 of 34 Old 01-12-2011, 08:51 PM
carlitos_90
i have 93 94 and 95 2.5L ...and a 95 4.0 ... anything needed to check? on their be glad to help
carlitos_90 is offline
post #25 of 34 Old 01-13-2011, 12:12 AM
SpideYJeep
Originally Posted by timatoe View Post
That's oil pressure, engine coolant temp. is, driver side rear corner, next to the valve cover.
fgcox, the sensor may only appear to be a stud sticking up from the head.
Tnx Fred
No love for timatoe?
Wrenching isn't the problem, it's the brains attached to the hands...unfortunately, I'm lacking some of the former so that's why I'm asking you guys!!
Originally Posted by YJake View Post
My YJ is so excited it's leaking oil!
SpideYJeep is offline
post #26 of 34 Old 01-13-2011, 06:06 AM
Que89YJ
Temp sensor
Here is a good post for function:
Que89YJ is online now
post #27 of 34 Old 03-02-2011, 09:41 AM
ckimbrough66
i have the same wire loose. would that cause any problems? like my yj running very rough?
ckimbrough66 is offline
post #28 of 34 Old 03-02-2011, 10:29 AM
Que89YJ
Not from the temp sensor in the rear of the engine. It is strickly for the guage.
post #29 of 34 Old 03-02-2011, 12:26 PM
Berniebikes
Well, this thread is clear as mud. Too many engines, too many combinations/variations. I will add to the original description regarding temp sensors/switches for the 4.2 L carbed engine. this engine actually has 3 temp sensors. Two are located on the driver's side manifold.
Usually the two wire switch is in the forward location, the single wire switch is in the rear location, but on my engine they are reversed. Doesn't make any difference as they both will measure the coolant temp. The single wire switch is used for the intake manifold heater operation. The two wire switch is used for the operation of the closed loop system with the ECM and in conjunction with the Thermal Electric Switch in the air cleaner.
On the rear of the block next to the valve cover and by the firewall is the third coolant temp sensor which operates the gauge on a 4.2L engine. It has a single purple wire to it as shown here.
This applies pretty much to all stock 4.2L engines, though many folks have no need for the either of the two manifold mounted if they have nuttered their engines and removed or disabled their intake heaters. Hope this clarifies things some.
b
Berniebikes is offline
post #30 of 34 Old 09-15-2011, 09:42 AM
87yjrad
Thanks Bernie! That's exactly what I needed. I just did a Howell FI conversion and can't get my temp gauge working. That helps a lot because I saw three sensors but didn't know what each one did. I'll get it not. Cool.
87yjrad is offline
What voltage at coolant temp sender? UnderDog! YJ Wrangler Technical Forum 0 10-01-2009 08:28 PM
Coolant Temp Switch (Sender) rmorrison9773 YJ Wrangler Technical Forum 0 06-01-2009 07:17 AM
2.5 Coolant Temp Sensor Thread Size? Thee_Nickster YJ Wrangler Technical Forum 1 04-20-2009 09:27 AM
New coolant temp sender with Carter carb traumajunkey YJ Wrangler Technical Forum 2 03-24-2009 04:09 AM
Temp Sensor / Coolant Temp Sending Unit malone_ge YJ Wrangler Technical Forum 1 03-01-2007 09:41 AM
