UJ help!!!!! and stutter problem!!! - JeepForum.com
post #1 of 4 Old 06-10-2010, 04:11 PM Thread Starter
muddyfunkster
Hey two questions!
Had major vibes for a while, getting worse and worse, getting worse with speed.
Replaced front driveshaft which had worn slipyoke, Vibes got better for a while but were still there, then in last two weeks they got really bad to the point that it was really uncomfortable to drive!
Had a look underneath and both ends of the rear propshaft were leaking on the oil seals and the UJ had some play in it, when i rock it up/down hard i can see the uj moving in the cap slightly, then all of a sudden this week there is a dud dud dud noise that is in time with the vehicle speed and vibes.....so im guessing the rear UJ has gone?...
So In uk all i can find are front driveshaft UJ's, are they the same size as the rears??????
Question two - when i replaced the exhaust manifold I went to replace the intake and i noticed it had slipped while being moved out of the way and was pulling the one of the injector wires (I left the wiring attached) it hadnt pulled it off but was stretching it.
now i have really bad problems with the jeep bucking and stuttering bad, to the point where it wont go! i looked at the wire nearest the firewall and wiggled it etc and the jeep was drivable but it still stuttered slightly, do you think i broke the wire? the jeep has never done anything like that before!
Thanks for any help!
He who sees last.... gets stuck first!!!!!!!!!
muddyfunkster is offline
post #2 of 4 Old 06-10-2010, 04:22 PM Thread Starter
muddyfunkster
Forgot to say, put new 02 sensor and TPS on at the same time, but no codes are coming up - dodgy 02 sensor?
argh!!!!!!!!!
post #3 of 4 Old 06-11-2010, 09:38 AM Thread Starter
muddyfunkster
No replys?!!!!!!! Is it coz I is English??? lol!!!!!!!!!
post #4 of 4 Old 06-11-2010, 10:05 AM
muddy93
1987 FSJ Wagoneer
with oil on both ends of the rear drive shaft (guessing that's what you meant when you said "propshaft"), I'd start by checking the fluid level in both the T-case and rear axle. Also, if there is any play in the yoke on the rear axle, you might be in need of new pinion bearings.
maroon 1987 Grand Wagoneer. stock for now...
muddy93 is offline
2.5 stutter 2k rpm's Eriks99tj TJ Wrangler Technical Forum 13 11-03-2010 08:36 PM
Did a tune up .. now CEL and stutter Emdot TJ Wrangler Technical Forum 5 08-02-2009 03:30 PM
New PCM did not fix stutter problem Luckyduck TJ Wrangler Technical Forum 7 08-03-2008 04:18 PM
Super Stutter problem-Test your diagnostic powers! zachattack1213 TJ Wrangler Technical Forum 17 01-09-2008 02:04 AM
disturbing stutter jolie TJ Wrangler Technical Forum 4 07-07-2007 01:44 PM
